Griffiths' Notation for Vector from Source to Field Point
  • Thread starter Thread starter radiogaga35
    Griffiths Notation
Griffiths' notation for the vector from the source point to the field point, referred to as a "squiggly r," simplifies complex expressions in his electromagnetism textbook. Users are seeking ways to reproduce this notation in LaTeX or standard symbol fonts. One participant found a site suggesting that the squiggly r is a special font created for Griffiths' book but could not verify this. Instead, they utilized the fcursive font package as a workaround. The discussion highlights the challenge of typesetting this specific notation effectively.
radiogaga35
Hi there
Griffiths uses a nice notation for the vector from the source point to the field point --a "squiggly r" -- in his E-M textbook. He calls it a "script letter". It makes many ugly expressions look much simpler.
Anyway, nice as it is, does anyone who has used Griffiths know how to produce that "squiggly r", in LaTeX or using some standard symbol font? I'm trying to typeset some stuff and I've been stumped trying to find it!
Thank you!
I remember looking for this about a year ago. After searching extensively, I came across a site claiming that this was a special font developed for the purpose of the book. Whether or not I believe it, after a couple days of searching, I hadn't found anything, so I ended up using the fcursive font package. Take a look and see if you can be satisfied with as little as I was =)
Good luck,
a.
Ok, thanks for the suggestion, I'll take a look!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
