Grounded Means Zero Electric Potential: Exploring the Method of Images
In summary, when discussing electric potential in relation to an infinite ground conducting plane, we must consider the use of infinity in mathematics and the convention of choosing zero potential. The plane must be infinite to maintain the math's reasonability, and its surface is an equipotential surface regardless of whether it is grounded or not. The method of images allows us to use a positive charge on the plane to create a zero potential, and this can also be seen in the formula for electric potential.
sinus
Can anyone explain to me why grounded means zero electric potential. I confuse what's the relation between infinite ground conducting plane and its electric potential (the method of images).
I have a several question:
1. Why the conductor plane must be infinite, while in reality there's no such one.
2. Why the electric potential must be zero to using this method?
2. If the plane isn't be grounded, does its electric potential not zero? What's exactly that making the potential in the plane zero when we grounded it? How ?
As far as I know that the electron easily run into the ground, does it mean the plane become positive charge?
HI,
It's all mathematics. A solution of the Laplace equation is unique. The math is reasonable when good use is made of infinity. So for your #1 question: to keep the math from becoming unpleasant.
#2: If the plane is conducting and not grounded and not neutral, it contributes to the electric field and needs to be taken into account. Its surface is still an equipotential surface, though.
That's just a conventient convention. All physics is independent of the choice of zero potential. Often infinity is chosen (but sometimes that doesn't work, for instance with the electric field of an infinitely long wire charge).
Yes ! That's the fun of the image method. And quite useful, to boot!
Likes sinus
BvU said:
HI,
That's just a conventient convention. All physics is independent of the choice of zero potential. Often infinity is chosen (but sometimes that doesn't work, for instance with the electric field of an infinitely long wire charge).Yes ! That's the fun of the image method. And quite useful, to boot!
Thanks a lot, but I still a little bit confused, why then the plane that have positive charge has zero electric potential?
If we take a case of point charge in space at coordinat position x,y; does that mean electric potential exactly at that x,y is zero? Where the charge is, the potential right at that charge place is zero and only its surrounding that have a potential? And similiarly to a charged plate?
BvU said:
HI,
how it can be zero, while the plane have charge? If we look to the formula that:
V=k(q/r), at any point as long as the point is right on the plane then r =0, how "k and q" divides zero become zero?
A conducting grounded plane (infinitely large to keep thing simple) is an equipotential surface (otherwise charges would move until it was). If you place a charge ##q## above it at a distance ##d##, the plane still remains an equipotential surface, so things must happen:
A nonzero surface charge distribution builds up on the top surface in such a way that the plane still remains an equipotential surface. The electric field lines just above the top surface have to be perpendicular to the plate (or else the charges would move along the surface).
Since a configuration with an imaginary charge ##-q##, at ##-d## opposite the actual charge causes exactly the electric field distribution in space that satisfies these conditions (zero potential at the surface and field lines perpendicular to the surface) AND a solution to the Laplace equation is unique, this mirror method is justified.
With Gauss' theorem you can find the induced surface charge distribution. The integral of the surface charge over the entire top surface is ##-q##.
NO ! A point charge is a singularity. The electric field and the potential at its exact position are infinite (in the convention that field and potential are zero at infinite distance from the point charge.
I don't follow. How can what be zero ? Are you mixing up an equation for the potential field caused by a single point charge in space with a potential field (*) caused by a charge distribution on a plane ?
(*) in the half-space above the plate
Likes sinus and PhDeezNutz
All potentials are differential, measured between points. Defining a perfectly conductive plane as zero potential provides a reference for all potential measurements. What happens above the plane will be reflected by the plane like a mirror, which will invert the potential of the virtual image below the plane.
If the plane is defined as being infinite, it becomes unnecessary to specify the boundary. That makes it easier to handle situations where an image may or may not form. It also eliminates peripheral currents along the boundary of the plane, and reflections of currents from the boundaries of the plane.
If the potential of a point above the ground plane is +v, then the image below will appear to have a potential of -v. If the ground plane was not at zero potential, symmetry would be lost, and the analysis would rapidly become intractable.
  • Love
Likes sinus and BvU
NO ! A point charge is a singularity. The electric field and the potential at its exact position are infinite (in the convention that field and potential are zero at infinite distance from the point charge.I don't follow. How can what be zero ? Are you mixing up an equation for the potential field caused by a single point charge in space with a potential field (*) caused by a charge distribution on a plane ?
Thank you so much for your explanation, I finally understand. I'm sorry for my question that make you confused and sorry for long time I didn't reponse. It's because my mind that make it look like it complicated when it wasn't :)
Likes BvU
Baluncore said:
All potentials are differential, measured between points. Defining a perfectly conductive plane as zero potential provides a reference for all potential measurements. What happens above the plane will be reflected by the plane like a mirror, which will invert the potential of the virtual image below the plane.If the plane is defined as being infinite, it becomes unnecessary to specify the boundary. That makes it easier to handle situations where an image may or may not form. It also eliminates peripheral currents along the boundary of the plane, and reflections of currents from the boundaries of the plane.If the potential of a point above the ground plane is +v, then the image below will appear to have a potential of -v. If the ground plane was not at zero potential, symmetry would be lost, and the analysis would rapidly become intractable.
Thank you so much for your explanations:)
FAQ: Grounded Means Zero Electric Potential: Exploring the Method of Images
What is the method of images in electrostatics?
The method of images is a mathematical technique used in electrostatics to simplify the calculation of electric fields and potentials. It involves replacing a complex boundary condition problem with an equivalent but simpler problem by introducing imaginary charges (images) outside the region of interest. These image charges are placed in such a way that the boundary conditions are satisfied, allowing for easier computation of the electric potential and field.
How does grounding affect electric potential?
Grounding an object means setting its electric potential to zero. In practical terms, this means connecting the object to the Earth, which can absorb or supply an infinite amount of charge without changing its own potential. Grounding serves as a reference point for measuring electric potential and ensures that any excess charge on the object is neutralized, thereby maintaining a stable potential of zero.
Why is zero electric potential important in electrostatics?
Zero electric potential is important because it serves as a reference point for measuring the potential of other charges and systems. In electrostatics, potential differences drive the movement of charges. By defining a point as having zero potential, typically by grounding, we can more easily calculate and understand the behavior of electric fields and potentials in a given system.
Can you provide an example of using the method of images?
One classic example of using the method of images is calculating the electric field near a grounded conducting plane. Suppose we have a point charge +q located a distance d above an infinite grounded conducting plane. To solve for the electric field, we introduce an image charge -q located a distance d below the plane. This setup ensures that the potential on the plane is zero. The resulting electric field is then the superposition of the fields due to the real charge and the image charge, simplifying the problem significantly.
What are the limitations of the method of images?
The method of images is a powerful technique but has limitations. It is primarily useful for problems with high symmetry, such as those involving infinite planes, spheres, or cylinders. For more complex geometries, finding the appropriate image charges that satisfy the boundary conditions can be extremely challenging or impossible. Additionally, the method is mostly applicable to electrostatic problems and may not be directly applicable to dynamic or time-varying fields.
