Group I/II Metal oxides always basic in aqueous solution -- why?
  • Thread starter Thread starter adf89812
    Metal
Group I and II metal oxides in aqueous solutions are considered basic due to their lower electronegativity compared to non-metals. This property allows them to act as proton acceptors, facilitating the release of hydroxide ions in water. The discussion highlights that when these metal oxides dissolve, they donate electrons to hydrogen, leading to the formation of hydroxide ions as hydrogen detaches from water molecules. In contrast, non-metal oxides, being more electronegative, tend to form larger acid molecules without releasing protons as readily, resulting in acidic behavior. The conversation emphasizes that electronegativity is an intrinsic property of elements and does not diminish upon bonding, suggesting a need to explore the net electronegativity effect in compounds to fully understand these behaviors.
adf89812
TL;DR Summary
Make argument rigorous
Transform my handy-wavy explanation of why group I/II metals oxides in aqueous solution are basic into a rigorous argument​
I heard an explanation about something being a better proton acceptor or lone pair donor but that doesn't make sense. I couldn't explain in in terms of acid-base theory.
The hand-waving way I saw it was that group I/II metal oxides are less electronegative than non-metals, so in water, they'll donate their electron to the hydrogen, the hydrogen will break away from the oxygen because hydrogen hates oxygen hogging its electrons, and because hydrogen electronegative enough.
With non-metals, my hand-waving is that metal oxides are more electronegative, when they bond with water, they'll just form one bigger molecule because they suck on other's electrons without letting go and form one big acid molecule where the least electronegative thing in there is a hydrogen, which falls of into a proton, and it may or may not be polyprotic.
Chemistry news on Phys.org
Electronegativity is a property of an element, not of a compound.
electronegative doesn't disappear when you form a chemical bond. Oxygen doesn't become less electronegative AFAIK when it bonds.
Maybe there's something about net electronegativity effect in molecules?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
