Hamiltonian system - qual question
In summary, for a planar Hamiltonian system with a C^2 function H(x,y) and only finitely many critical points, if the limit of |H(x,y)| tends to infinity as x^2+y^2 tends to infinity, then the system must have at least one Lyapunov stable critical point, which must be a center point.
triamine
This was on a previous qualifying exam. Let H(x,y) be C^2. Assume that [tex]\lim_{x^2+y^2}{|H(x,y)|} = \infty[/tex] and that the system [tex]\dot{x} = H_y, \quad \dot{y} = -H_x[/tex] has only finitely many critical points. Prove that it has at least one Lyapunov stable critical point.
Now, what I know is that for a planar Hamiltonian system, all of the critical points must be saddles or centers (look at the trace of the linearization of the system). Thus, the problem is equivalent to saying that a planar Hamiltonian system must have at least one center point (as saddles are not Lyapunov stable). I'm pretty much stuck after that though. Any ideas? Thanks in advance.
Here is one way to approach the problem: First, note that the given limit implies that H(x,y) must be unbounded as x^2+y^2 tends to infinity. Thus, there must be at least one critical point on the boundary of the region for which the limit is taken. Now, consider a Lyapunov function V(x,y) for the system, such that V(x,y) is bounded and tends to infinity as x^2+y^2 tends to infinity. This implies that all critical points of the system must be in the region for which V(x,y) is bounded. Next, note that since there are only finitely many critical points, there must be at least one critical point in the interior of the region for which V(x,y) is bounded. Since this point lies in the interior of the region, it follows that it must be a center point (as any saddle point would lie on the boundary of the region). Thus, the system must have at least one Lyapunov stable critical point.
FAQ: Hamiltonian system - qual question
What is a Hamiltonian system?
A Hamiltonian system is a mathematical model used to describe the behavior of a physical system over time. It takes into account the position and momentum of all particles in the system and uses Hamilton's equations to determine their evolution.
What is the significance of a Hamiltonian system?
Hamiltonian systems are important because they can accurately predict the behavior of physical systems, such as the movement of planets, atoms, and particles. They also have applications in fields such as engineering, physics, and mathematics.
What are the key components of a Hamiltonian system?
A Hamiltonian system consists of a set of equations known as Hamilton's equations, which describe the evolution of the position and momentum of particles in the system. It also includes a Hamiltonian function, which represents the total energy of the system.
Can a Hamiltonian system be solved analytically?
In some cases, a Hamiltonian system can be solved analytically, meaning that a closed-form solution can be found. However, this is not always possible, and numerical methods may need to be used to approximate the solution.
What are some examples of Hamiltonian systems?
Examples of Hamiltonian systems include the motion of objects in a gravitational field, the dynamics of a pendulum, and the behavior of gas particles in a closed container. Other examples can be found in quantum mechanics, statistical mechanics, and celestial mechanics.
