Hammer press equivalent to 6 Ton hydraulic press
A 3-ton hammer press may be used for forging operations previously done with a 6-ton hydraulic press, but the processes differ significantly. The hydraulic press applies pressure gradually, while the hammer press delivers rapid impacts, potentially affecting the material properties. There is no exact equivalence between the two types of presses, as the deformation rates and die requirements vary. The actual force needed for the forging operation may be less than the maximum capacity of either press. Therefore, it is possible to achieve similar results with the smaller hammer press, depending on the specific application and conditions.
LALIT NEGI
TL;DR Summary
i need a help, this is my first post in this platform, actually few year ago I perform a forging operation in a 6 Ton forging press but now i have 3 Ton hammer press, can i use that press to make that product.
is there any calculation to find out equivalent hammer press of a forging press
I'm really no expert on this materials processing question, but I doubt that an exact equivalence can be established. With the hydraulic press, the metal deformation is relatively slow and continuous. With the hammer press, the metal deformation is very rapid. I would expect significantly different properties in the resulting forged material in these two processes.
Welcome to PF.
The rating in tons is probably 1:1, only the time is different.
The forging press would build up pressure on the die gradually, until the process completed. The hammer press will apply a single impact, that may require the dies be mounted differently as excess force must be carried by the die.
Is the pressed material hot or cold? Is the workpiece being bent or coined?
If the process was previously done OK in a 6 ton press, that does not mean it required all 6 tons. It may only require one ton, so it could well be done in the 3 ton hammer press.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
