Harmonics, Notes, Beat frequency
In summary: Thus, different instruments playing the same musical note are characterized by different spectra of harmonics (as well as differences in attack and decay of the note, etc.).
Bengo
46
When an instrument plays a note, the resulting sound is a combination of all the possible harmonics for that instrument in its momentary configuration. For instance, a musician changes notes on a violin by pressing the strings against the neck of the instrument, thus shortening the string length and changing the possible harmonics. A given shortened string will play at one time all the possible harmonics allowable by its string length. A given note is the same set of harmonics for all instruments.
1. Doesn't a wavelength have an infinite possibility of harmonics?
2. Why is there no beat frequency if each harmonic has a different frequency.
These aren't actual questions from my study books but they are really confusing to me.
1. f=nv/2L
2. beat frequency= abs (f1=f2)
1. My reasoning for thinking that there is an infinite number of possible harmonics is that you can keep increasing n in f=nv/2L.
2. Maybe there is no beat frequency because the frequencies are not close enough together or maybe the fundamental frequency "envelopes" the rest of the harmonic frequencies?
In theory that is correct, but the amplitude of the harmonics usually decreases as n increases, and also you can only hear a finite number of harmonics because of the limited range of human hearing (about 20 Hz to 20000 Hz).
The number of audible harmonics in the sound of different instruments can vary from only 2 or 3, up to more than 30.
From your formula, the beat frequency between two harmonics m and n is the same frequency as another harmonic, abs(m-n). So "beats between harmonics" don't create anything new in the sound.
Likes 1 person
Bengo said:
1.
No. The thing that distinguishes one instrument from another, all playing the same fundamental frequency (e.g. A=440 Hz which is A above middle C) is the variation in amplitude and phase of the various harmonics.
FAQ: Harmonics, Notes, Beat frequency
1. What are harmonics?
Harmonics are frequencies that are multiples of a fundamental frequency. They are produced when an object vibrates at a certain frequency, creating overtones that are related to the fundamental frequency.
2. How are harmonics related to notes in music?
In music, each note corresponds to a specific fundamental frequency and its harmonics. The first harmonic is the same as the fundamental frequency and is known as the note's "fundamental." The following harmonics are used to create the unique sound and tone of each note.
3. What is beat frequency?
Beat frequency is the difference between two frequencies that are close to each other. When two sound waves with slightly different frequencies are played together, they create a pulsating or beating effect. The beat frequency is the number of pulses or beats that occur per second.
4. What is the relationship between beat frequency and harmony?
Beat frequency is an important aspect of harmony in music. When two notes with different frequencies are played together, the beat frequency can create a pleasing or dissonant sound, depending on the ratio of the two frequencies. In harmonious music, the beat frequency is often used to create a sense of tension and resolution.
5. How do harmonics and beat frequency affect the quality of sound?
Harmonics and beat frequency play a crucial role in the quality and timbre of sound. The presence and balance of harmonics can greatly influence the richness and complexity of a sound, while beat frequency can add depth and texture. These elements are often carefully controlled and manipulated in music and sound production to create desired effects.
