Stargazing Has a Deep Field Picture of the Sky Been Captured with a Radio Telescope?
  • Thread starter Thread starter zuz
    Picture Sky
Deep field images of the sky using radio telescopes have been explored, with early efforts from instruments like the Big Ear and Mills Cross. The Five-hundred-meter Aperture Spherical Telescope (FAST) excels in pulsar detection due to its larger aperture but is limited in deep sky imaging due to its single location and sensitivity issues. High-resolution deep sky observations require techniques like Very Long Baseline Interferometry (VLBI), which involves international collaboration and significant numerical processing. The Square Kilometre Array (SKA) is positioned to achieve much higher resolution for deep sky observations due to its distributed aperture and steerable elements. Overall, while progress has been made, challenges remain in capturing detailed deep field images with radio telescopes.
zuz
Has anyone ever taken a "deep field" picture of the sky, like Hubble, but with a radio telescope?
Astronomy news on Phys.org
Some of the early radio astronomical survey mapping was done by telescopes like "Big Ear" in the North, or by the Mills Cross in the South.
https://en.wikipedia.org/wiki/Ohio_State_University_Radio_Observatory
https://en.wikipedia.org/wiki/Mills_Cross_Telescope
To get deeper detailed images of smaller areas, requires VLBI, with international collaboration. The construction of detailed radio images, from the VLBI time data, requires intensive numerical processing. An optical image can be accumulated, on an image sensor array, which is a faster parallel process.
All that exists at FAST but all publications I could find from them were pulsars and FRB and again pulsars, i.e. only the sources that were very bright for the telescope. I wonder whether this is for a reason or due to the relatively young age of FAST.
Deep sky observations require high sensitivity and high resolution. Unfortunately, man-made interference, and nearby bright sources, raise the noise floor of the synthesised images.
The Five-hundred-meter Aperture Spherical radio Telescope (FAST), operating alone, is a single location observatory. Resolution is limited by the 500 metre diameter. FAST finds more pulsars because it has a larger aperture area, and therefore has higher sensitivity than earlier observatories. It can make point measurements, where the signal is the sum of all the beam energy. That is suited to strong signals, or pulsar observations, not deep sky.
https://en.wikipedia.org/wiki/Five-hundred-meter_Aperture_Spherical_Telescope
The Square Kilometre Array (SKA) has a distributed aperture, so should have over 1000 times the resolution of FAR, since SKA is designed to operate as a long baseline interferometer. That would be more suited to deep sky observations, if you can find and fund the computer time.
https://en.wikipedia.org/wiki/Square_Kilometre_Array
FAST is located at about 26° North, and zenith limited, so is restricted to the northern sky. It is not as steerable as the elements of the SKA.
The SKA is based in Africa and Australia, with many more steerable elements. It is better positioned to observe the southern sky with the best view of the Milky Way.
Thank you. That is just what I was looking for.
Likes pinball1970 and berkeman
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
