I Hawking After 54 Years Confirmed: BH surfaces don't shrink
  • I
  • Thread starter Thread starter fresh_42
fresh_42
Staff Emeritus
Insights Author
2024 Award
TL;DR Summary
GW250114: Testing Hawking’s Area Law and the Kerr Nature of Black Holes
Abstract​
The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1.
3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar (ℓ=|𝑚|=2) mode of a Kerr black hole and its first overtone. We constrain the modes’ frequencies to ±30% of the Kerr spectrum, providing a test of the remnant’s Kerr nature. We also examine Hawking’s area law, also known as the second law of black hole mechanics, which states that the total area of the black hole event horizons cannot decrease with time. A range of analyses that exclude up to five of the strongest merger cycles confirm that the remnant area is larger than the sum of the initial areas to high credibility.
Source: https://journals.aps.org/prl/abstract/10.1103/kw5g-d732
Note that this law only holds if energy conditions on the matter are satisfied. In the case of black hole mergers being observed by LIGO, they will be; but that's not the same as saying they always will be. This paper does not give evidence that black hole evaporation can't happen. It just shows that, as we already expected anyway, if black hole evaporation does happen, it happens on time scales many orders of magnitude longer than the time scale for black hole mergers.
Likes phinds and fresh_42
I am trying to understand the meaning of Hawking's area law in simple terms and why it needs to be a law and not just a "natural" consequence.
If the area of a black hole is the geometric area of the event horizon, i.e. ##A = 4\pi r^2##, and the radius of the event horizon is proportional to the enclosed mass, e.g. ##r = 2Gm/c^2##, then we have BH area proportional to the square of the mass, ##A = km^2## with ##k = \left( {4\sqrt{\pi}G} / {c^2} \right)^2##. If two such (simple) black holes merge their mass adds up, so I would expect the area of the combined BH to be ##A_{12} = k(m_1 + m_2)^2 = k(m_1^2 + m_2^2) + 2k m_1 m_2 ## which is clearly always bigger than the sum of the area of the two original BH with value ##A_{1+2} = k(m_1^2+m_2^2)##, that is ##A_{12} = A_{1+2} + 2k m_1 m_2##.
To the extend that the above simplifications holds, at least for the simple BH solutions, my question would now be if there is a simple explanation as to why Hawkin's area law need to be a law and not just seen as a "natural consequence"?
Skimming the paper linked in #1 (and reading the piece Arstechnica had on it) I understand the experimental confirmation is based on "matching" simulations of the merger with observations and thereby establish a credible model for the pre- and post-merge BH's allowing to "measure" the BH properties by simply extracting this from the model. If so, I guess my question above could also be formulated as:
Do such models used for simulations of BH merger's (A) have a "free parameter" that in one range would allow mergers where Hawkin's area law hold and another range where it does not, and the present experimental observations then "matched" this parameter to be in the "hold range"? Or is it more like (B) that all merger simulations always result in Hawking's area law being valid (as a result of the underlying dynamics) and the present experimental observations then "just" confirmed that the model can be matched observation in general?
It is not my understanding that (A) is the case but if this means (B) then again I am (again) puzzled as to why Hawkin's area law needs to be a law in the first place.
Reading the paper more slowly (after discovering that most of it is surprisingly readable even for people only vaguely aware of BH terms and theory) it does seems the authors did provide a nice explanation of what could theoretically break the area law:
The area law relies on three conditions. The first is the null-energy condition, a restriction on the properties of matter. It is violated, for example, by Hawking radiation which extracts energy from a black hole and causes its horizon to shrink —in this case, the area law is superseded by a generalized law that considers both the entropy of the black hole and that of the radiation . The second is the premise that the observed objects are black holes and weak cosmic censorship holds, i.e., no naked singularities. Alternative compact objects have modified entropy and violate the null-energy condition; their interactions could violate the area law. The third is general relativity; the area law can be violated in alternative theories . Testing the area law thus amounts to testing for physical behavior that violates at least one of these conditions.
So, I guess it is fair to say that the area law was historically speaking a law, but is now more seen as a theoretical consistent consequence under the stated assumptions?
@Filip Larsen what do you mean by a natural consequence and why do you think it is not? Of course, it follows from general relativity and the assumptions in the theorem. And of course a theorem like this can be called a law of physics, why is that a problem!
More like B, they talked about this on a Spanish podcast last week and the general criticism was what you point out in B
Likes Filip Larsen
As a layman I was just trying to understand why the paper and the news about it emphasized or singled out the area law as being confirmed, as opposed to simply say the measurements confirm theory of general relativity with the stated assumptions about the participating black holes. From the news I originally took this to mean that the area law somehow was a separate thing on top of GR that would need independent experimental verification, but now I understand the area law as a kind of prediction based on GR with some assumptions about the black holes in question.
And don't get me wrong. If this, as I also understand it, is the first time LIGO observations has been accurate enough to say they significantly support verification of the area law then I guess that is worthy of special emphasis.
What's the difference?
I hadn't heard about Hawking's area law before (although I had heard about the connection between surface area and entropy) so I took the combination of "law" in the name and the prominent pop-sci news about this law now being experimentally verified to indicate that perhaps the area law was a sort of postulate on top of GR that now got confirmation. So I did some simple math as listed in #3, scratched my head in confusion and went on to ask on PF why this is prominent news and conveniently found this thread to post in.
As it were, once I took to read the paper slowly enough it did seem to explain the reasons very well so my question is no longer an unanswered question.
As you seem to realize now, it isn't. It's a mathematical theorem.
The main thing to understand about it, as you saw from the paper, is that one of the premises of the theorem is energy conditions that have to be satisfied. Those conditions are violated in postulated scenarios like black hole evaporation, which is why the total area of event horizons can decrease in such scenarios. But the time scale for black hole evaporation is many, many, many orders of magnitude too long for it to be significant in events like black hole mergers observed by LIGO, so the area theorem is expected to hold for such events.
Likes Filip Larsen
