Hazard levels for pressure vessels with internal bladders
The discussion highlights the complexities of classifying pressure vessels in Australia and the United States, particularly regarding water buffer tanks and accumulators with internal bladders. In Australia, the classification system is based on a pressure-volume calculation multiplied by service factors to determine hazard levels, which dictate inspection and design requirements. In contrast, the U.S. lacks a unified standard, relying instead on various industry-specific codes, including the ASME Boiler and Pressure Vessel Code, with inspections managed at the state level. The conversation emphasizes that risk assessment in the U.S. is often limited to prescriptive codes that categorize vessels rather than providing a comprehensive evaluation of risk. Overall, the need for clearer guidelines and standards for pressure vessel classification and risk assessment is evident.
LT Judd
TL;DR Summary
What is the US system for classifying pressure vessels to determine hazard levels and required level of design and inspection oversight.
Hi , I am based in Australia and my question originates from some grey areas in the Australian system of classifying pressure vessels. I am guessing most users on this forum are US based . Does the US have a system for classifying pressure vessels such as air receivers , boilers, autoclaves, heat exchangers etc. to determine what level of inspection and design review is required?. If so could some one briefly describe it. From what I have seen on the web it looks like you don't have a general standard , but different standards depending on the industry and application. I am interested particularly in the case of water buffer tanks and accumulators that have a bladder inside them filled with nitrogen and how they are considered in terms of risk and hazard.
The Australian system is, I think, based on a German one in which you start with a pressure X volume figure ( MpA x Litres) and then mutiple by 3 different service factors to get a hazard number. The hazard numbers are then divided into five different bands (Logarithmically) which call out different requirements involving design, verification inspection and operation.
We have ASME boiler and pressure vessel code, but inspections are a state (or insurance) thing. I live in Pennsylvania and we have our own PVC that sits over top of ASME for administration.
It seems to me that risk assessment is limited; the codes are prescriptive and you just find what category yours is in (unfired pressure vessel).
https://www.dli.pa.gov/Individuals/...ges/Boilers-and-Unfired-Pressure-Vessels.aspx
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
9K
14K
