MHB Hcc8.11 change each to complex form and find product
The discussion focuses on finding the product of the complex numbers (1+3i) and (2-2i), resulting in 8 + 4i. Participants clarify the terminology, suggesting that "complex form" should be replaced with "Cartesian form" and "Polar form." De Moivre's Theorem is mentioned as a relevant concept for converting complex numbers. The conversation highlights the importance of clear communication and proper terminology in mathematical discussions. Overall, the thread emphasizes understanding complex numbers and their representations.
karush
MHB
$\tiny{hcc8.11}$
$\textsf{Find product $(1+3i)(2-2i)$}\\$
$8 + 4i$
$\textsf{Then change each to complex form and find product. with DeMoine's Theorem}$
$\textit{ok looked at an example but ??}
Mathematics news on Phys.org
What you're asking is not clear. Can you quote directly from your source? Do you mean "DeMoivre's theorem"?
basically yes
but this got answered
it was on a hand out which was hard to read with little information.
You probably should not use the phrase "complex form" here. These are complex number which are typically written in one of two forms, "Cartesian form", which is what you have, and "Polar form", "r(cos(\theta)+ i sin(\theta))" or (an engineering notation) "r cis(\theta)". For "a+ bi", r= \sqrt{a^2+ b^2} and \theta= tan^{-1}(b/a) (as long as a is not 0. If a= 0 \theta= \pi/2 (if b> 0) or \theta= -\pi/2 if b< 0). if a=b= 0, r= 0 and \theta can be anything.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
10K
