Misc. Headwater: 2" drop in a 40 foot length culvert
  • Thread starter Thread starter John1397
    Drop Length
To determine the headwater for an 18-inch culvert with 13.5 inches of water at the inlet and a 2-inch drop at the outlet over a 40-foot length, a comprehensive approach is necessary. The flow rate, referred to as "fps," is crucial for understanding the culvert's performance. Calculating flow through the culvert involves considering various factors including the culvert dimensions, shape, roughness, slope, and water levels at both the inlet and outlet. The flow can be categorized as under inlet control, outlet control, or in a transition state, which affects the calculations. For accurate results, it's recommended to consult the Hydraulic Design of Highway Culverts (HDS5) reference, while being cautious of potential errors in nomograms.
John1397
TL;DR Summary
How to figure headwater
I am trying to figure out the fps of 18 inch culvert with 13.5 inches water over the top on inlet and about 2 inches lower on the outlet and 2 inch drop on the outlet end over 40 foot length, what I need to know what would be the headwater on this type of configuration?
John1397 said:
Summary: How to figure headwater
Sorry, what is the "fps" that you are asking about? Are you asking what the flow rate would be for a water channel that has a drop of 2" over a 40 foot length? If so, the answer is very small -- hopefully you are not trying to generate any useful energy out of this flow...
It sounds like you want to calculate the flow through a culvert, given some dimensions and depths. There is no one equation to calculate this. There is a procedure that takes into account the culvert dimensions, culvert shape (round vs arch bottom), roughness (CSP vs concrete vs plastic vs ...), length, slope, headwater level, tailwater level, water approach velocity and direction, tailwater velocity, entrance configuration, etc. That procedure starts by determining whether the flow is under inlet control, outlet control, or in the transition region between. Here is a link to the standard reference, HDS5 Hydraulic Design of Highway Culverts, 3rd Edition: https://www.fhwa.dot.gov/engineering/hydraulics/pubs/12026/hif12026.pdf.
Be advised that at least one of the nomograms is in error by more than an order of magnitude, so use the equations.
Likes BillTre and berkeman
Seen that throwing stick in water time how many seconds from into out works to.
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
