Heard About this TI product :Jacinto ?
  • Thread starter Thread starter Chandra214
    Product
The TI Jacinto is a dual-core processor, specifically the DRA440, featuring an ARM926Ej core, and is aimed at automotive and consumer markets. It is not related to the TI Piccolo series, and there is limited publicly available documentation, suggesting TI may not want it widely marketed to prevent hacking. Microsoft is reportedly supporting Jacinto through its Microsoft Auto 3.1 software package. Some believe TI may be transitioning from the Jacinto branding to the DaVinci line. Overall, Jacinto serves as a cost-effective media processing engine for automotive infotainment applications.
Chandra214
Heard About this TI product :Jacinto ??
has anyone heard or worked on TI Jacinto.
I was not able to find any documentation on this.
Is this same as TI Davinci?
This class explores a real-life example of integrating a real-time operating system with TI AVME DSP software on the TI Jacinto/ DaVinci platform for automotive and consumer markets. Attendees will learn how design choices for multimedia-enabled products can impact time-to-market, material costs, reliability and upgradeability.
http://training.ti.com/courses/CourseDescription.asp?iCSID=57424"
I had not heard of "Jacinto" earlier.
It seems to be a dual core processor : DRA440. with an ARM926Ej core,
It is not related to Piccolo!
ha! it is hard to find much on it. i get the impression it's not going to be marketed publicly because they don't want people hacking it. here's a pdf, one of only 3 jacinto docs showing up at ti.com. and microsoft seems to be supporting it too, in a Microsoft Auto 3.1 software package.
http://focus.ti.com/lit/ml/sprp573/sprp573.pdf
i suspect you won't find any documentation for this unless you can somehow discover what the actual TI product used is. it may be very similar to some other off-the-shelf TI product.
edit: you know, on second thought, maybe they're just abandoning the Jacinto code name and going with branding as Davinci
http://www.ti.com/corp/docs/landing/davinci/news.html
I think this statement helps
" Jacinto (552MHz DSP, 348MHz ARM926E-JS and OMAP5946) a cost effective media processing engine for Automotive Infotainment applications, mainly to enable head-unit, rear seat entertainment and digital radio designers to create scalable reusable hardware and software platforms."
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
