Heat and Infrared radiated from an object
In summary: Firefly light doesn't produce heat, but that doesn't mean there isn't energy involved. Firefly eyes are capable of detecting light between the infrared and visible ranges, so they're not blind in the middle.
LightningInAJar
220
30
TL;DR Summary
Infrared without heat?
Dumb question.
Is there a direct heat energy relationship between a heated object and infrared radiation? 1 to 1 relationship? Or can IR go up without there being much heat?
Your question has a couple of oops statements I think.
And this answer will not really answer your questions since I'm confused
For heat let's use degrees K (or Celsius). Ok?
The first problem is that IR is just a part of a spectrum: gamma rays, x-rays, ultraviolet, visible, microwave, IR, radio. So microwaves make "heat" when they hit water molecules, for example. Visible light feels warm on your skin. So it can "heat" your skin, as another example. IR can do the same thing.
gamma rays can disrupt chemical bonds.
So, help me out here. What do you want to know? This is a huge topic.
Sorry for the marginal answer, best I could do.
Also pleas tell us if you are interested in heat or temperature
There's nothing special about the infrared spectrum, excepting that - at the temperatures we're used to, on Earth - it makes up the bulk of thermal radiative emission/absorption.
Assuming you are asking about the IR emitted by a hot object, there is absolutely a relationship. Most objects closely obey Planck's Law, which let's us calculate how much power is emitted by an object in various electromagnetic frequencies, including IR. In general, the hotter something is, the more radiation it emits and the higher the average frequency of this radiation is. So an ice cube emits less radiation than my big fat cat who's occupying my lap currently, and the radiation the ice cube emits is of a lower frequency on average.
This is why heating up a piece of metal turns it first red, then orange, then white and explains why it becomes increasingly brighter as it heats up. At first the temperature is too low to emit hardly any visible light, so the metal is just its normal color, though it might me scalding hot and you can feel the IR radiation it emits if you hold a hand close to it. Once the metal heats up a bit more it becomes a dull red and you can see it glowing, even in the dark. Hotter still and it becomes orange, then yellow, then white. As it gets yellow and then near white the amount of radiation it emits in the visible frequencies is so much that it could light up a room. As well it should, as this is exactly how an incandescent light bulb functions.
Hotter still, such as when arc welding, and you start to get appreciable amounts of UV radiation. This is why they say never watch someone welding or you'll hurt your eyes.
Note that as you increase the temperature the amount of radiation produced at ALL frequencies increases. So metal that's white hot is emitting more IR radiation than when it was red hot.
Also, keep in mind that the color vs temperature scales you see online usually work pretty well for your eye, but not always for cameras, as the following video demonstrates:
More info:
https://en.wikipedia.org/wiki/Thermal_radiation
https://en.wikipedia.org/wiki/Black-body_radiation
Likes BvU, jim mcnamara and russ_watters
I am interested in IR radiation therapy that some medical researchers experiment with, but was wondering if high levels of heat are needed for higher levels of IR radiation? Perhaps depends on the material? I know fireflies produce light between red and green and produce no heat at all. Are you sure visible light produces heat?
Yes. All that IR radiation generated is absorbed by the person and felt as heat. There's no way to get around this if the goal is to pump IR radiation into someone.
Fireflies don't produce light via incandescence, which is what hot objects like incandescent light bulbs, hot metal bars, and stars do. Incandescence is the emission of electromagnetic radiation (including visible light) from a hot body as a result of its high temperature. Instead fireflies use bioluminescence, where a series of chemical reactions directly release light within a narrow band of frequencies. For fireflies there are several peaks in the spectrum between about 550 and 600 nm (source).
And just to be extra clear, there is a difference between something hot producing light vs light producing heat. A laser doesn't use heat to produce its light (by that I mean that the laser isn't incandescing), yet even lasers that use a tenth of the power of a common LED light bulb can burn through wood. Visible light produces heat when absorbed, as does all EM radiation including IR.
What exactly are you trying to do? I hope you're not planning on using it on yourself or anyone else. Under no circumstances should you ever perform any 'therapy' or any other medical procedure on yourself or others unless instructed to by a doctor. Even something seemingly mundane like IR therapy might lead to skin problems (or potentially something else) over time. I can't remember what it's called, but I do remember hearing something about the heat from laptops messing up people's skin from prolonged use. So now we have people with skin problems on their upper legs and groin from simply using a laptop every day.
Likes BvU
No, no self treatments. Just curious if one could get IR therapy without burning oneself.
bioluminescence can never emit light in IR spectrum?
Given the right molecules it might. It's just that IR radiation isn't a good way to 'see' due to its lower energy vs visible light. Visible light has enough energy to cause certain molecules to deform inside your eye, which is the first step in a cascade of reactions that enable you to see. IR, with its lower energy per photon, can't do this.
There's a deepsea nightmare fish that uses 708nm light (almost IR) to hunt prey
Everything at that depth has lost the red visual receptors (since red from the sun doesn't reach that far down, its useless).
So the fish has a flashlight : internally it starts off as blue-green luminescence, that absorbed by a protein which emits red, that through a brown filter that takes out almost everything, leaving only almost-IR. Which illuminates prey that can't see it.
But, the fish doesn't have any red receptors either.
Reflected light from the prey runs through a chlorophyll mechanism that upshifts it into the green which the fish does have receptors for.
As a final insult to sanity, the source of the chlorophyll is from the fish's prey's diet.
Likes Drakkith
That's pretty interesting.
FAQ: Heat and Infrared radiated from an object
What is heat?
Heat is a form of energy that is transferred between objects or systems due to a difference in temperature. It is typically measured in units of joules (J) or calories (cal).
How is heat transferred?
Heat can be transferred through three main mechanisms: conduction, convection, and radiation. Conduction occurs when heat is transferred through direct contact between objects. Convection is the transfer of heat through the movement of fluids, such as air or water. Radiation is the transfer of heat through electromagnetic waves.
What is infrared radiation?
Infrared radiation is a type of electromagnetic radiation that has longer wavelengths than visible light. It is invisible to the human eye, but can be detected by special instruments. All objects emit some amount of infrared radiation, with hotter objects emitting more infrared radiation than cooler objects.
How does an object's temperature affect the amount of infrared radiation it emits?
The temperature of an object directly affects the amount of infrared radiation it emits. The hotter an object is, the more infrared radiation it will emit. This is why objects appear to glow when they are heated to high temperatures, such as a red-hot piece of metal.
What is the relationship between heat and infrared radiation?
Infrared radiation is a form of heat energy. When an object absorbs infrared radiation, it causes the object's molecules to vibrate, which increases the object's temperature. Similarly, when an object emits infrared radiation, it loses heat energy and its temperature decreases.
