Heat capacity of air at low temperatures
The discussion centers on the search for tabulated values of heat capacity (c_p) and the ratio of specific heats (γ) for air at low temperatures and pressures. Users share various resources, including Perry's Chemistry Handbook and the NIST database, but note that much of the available data pertains to high pressures or the liquid phase. It is suggested that the specific heats are largely independent of pressure, allowing for the use of existing tabular values for calculations at low pressures and temperatures. Additionally, a computer database is mentioned as a tool for obtaining c_p and c_v values for air under varying conditions. The conversation concludes with appreciation for the shared insights and resources.
jpo
Hello,
would someone know where can one find tabulated values for the heat capacity of air c_{p} or the ratio \gamma = c_{p}/c_{v}?
I need those at low temperatures and pressures, e.g. tending towards zero.
So far I was only able to find \gamma tabulated for high pressures in Perry's Chemistry Handbook.
Many thanks in advance.
Science news on Phys.org
Thank you, nasu
these are at p = 1 atmosphere
I have been trying to find data for low pressures and temperatures
This is what I also found:
http://www.nist.gov/data/PDFfiles/jpcrd581.pdf
But the low temperature/pressure data is only on the dew/bubble lines where air becomes liquid...
I need data for air in the gas phase
Here's a source where you can determine Cp and Cv for the individual components (ie: N2, O2, Ar, etc...) for any pressure and temperature, though it doesn't combine those gasses in the form of air. I'm not absolutely sure but I would assume the overall Cp and Cv would simply be some function of the partial pressures.
http://webbook.nist.gov/chemistry/fluid/
Maybe someone else can provide a function for how they get combined.
If you can't get an answer or need to check the values, I have a computer database that can output Cp and Cv for air at any pressure and temperture.
Q_Goest,
thank you very much indeed
Perhaps this is the formula you were referring to
jpo said:
Thank you, nasu
Although gamma is a dimensionless number, its two components are not dimensionless. They are usually expressed in units of energy per unit of mass. As such, they are largely independent of pressure.
Specific heat at constant volume is obviously independent of pressure. Specific heat at constant pressure has the same value for a pressure of 50 hPa as for a pressure of 1000 hPa.
I think that you may safely use the tabular values in the Engineering Toolbox for your low pressure and low temperature calculations. Within the accepted limits of scientific accuracy and precision, of course.
I was able to find the book "Thermodynamic properties of air" and it will do
Thank you all for your replies
