"Heat resistance temperature" and melting point?
In summary: It always does, question is: how much and how fast. And yes, the higher the temperature, the faster these processes are. Still, around boiling point they are negligible, personally I wouldn't worry about it.
kenny1999
235
I've got a kitchen bowl made of polypropylene, it states that the "heat resistance temperature is 90 degree cel", while on Google, I found that the melting point of PP is 160 degree cel.
I understand that melting point is the temperature in which the atoms/molecules change its state from solid to liquid. How about the term "Heat resistance temperature"?
Chemistry news on Phys.org
I doubt it is something precisely defined in terms of physics. At best it looks like kind of an industrial standard saying "we guarantee it won't deform if you don't heat it above 90°C".
Also note that MP is a property of crystalline substances. PP is an amorphous substance that doesn't have a sharp melting point, it will slowly get softer and less viscous, to the point where it will just freely flow. Whole process will take place over a range of temperatures (that is, assuming it won't decompose first).
Likes Lord Jestocost
Hi, does "deform" mean "decompose" ? What is the difference between "Deform/Decompose" and "Melt" ??
No, "deform" means to change shape under an applied stress. PP will not decompose chemically at 90°C - if it did, there would be no sense in talking about a melting point at 160°C. There will be a test for heat distortion temperature (it may go by various names), which is defined as the temperature at which a test piece distorts by this much under this stress. This is somewhat arbitrary since, as @Borek says, it softens gradually over a wide temperature range.
PP is, however, a partially crystalline polymer - polymer chains will line up in a regular array in crystalline domains. These domains are embedded in regions of amorphous polymer; polymers are never fully crystalline.
The melting point is where these crystalline domains lose their crystalline order and become amorphous.
For PP, this is complicated by the fact that you have different stereochemical forms, where the stereochemistry (R/S) is the same from one propylene unit to the next (isotactic), or alternates (syndiotactic), or is random (atactic). Atactic PP is amorphous, and the other two forms have different melting points.
Hello. Thank you for the detailed explanation.
I have a new polypropylene kitchen bowl in which it states that the "Heat resistance temperature = 90°C", I wasn't aware of that and poured some freshly boiled hot water into it (should be around 100°C). In this case, would it cause any damage to the structure of the bowl and give out dangerous chemicals?? Is the bowl still safe for using?
Shouldn't do, but the bowl might have deformed if you'd put stress on it.
Likes kenny1999
Would "Deform" leach any chemicals? Or just a change of shape only?
At these temperatures it is only about shape change.
Likes kenny1999
Could it lose/leach any atoms/particles/compounds during the process?? Thanks
It always does, question is: how much and how fast. And yes, the higher the temperature, the faster these processes are. Still, around boiling point they are negligible, personally I wouldn't care.
Does "How much" and "how fast" also depend on the material? Is it safer to use food-grade stainless steel container compared to Polypropylene? It feels like stainless steel is stronger and their particles/atoms/compounds won't give out, true or not??
Yes.
More or less yes to both. Matter of price and ease of use, you don't want to drink from a metal cup as it burns. Still, PP is safe enough as long as you don't heat it above water BP.
Likes kenny1999
There would be some sense of talking about melting point at 160 degrees, though.
"Deform" means change shape.
"Decompose" means change composition. Whether the substances are given off or stay in the material.
Like deforming, decomposing takes time and is slower at lower temperature. Therefore, on rapid heating of a substance, you could have a modest amount of decomposition below the melting point which nevertheless has little effect on the melting point.
It's said that when Polypropylene is exposed to sunlight / UV, free radicals could be given out because of UV degradation. Where will those free radical end up in the air?? Otherwise than free radicals, any other chemicals would be given out when stressed by UV?? Are those free radicals and chemicals harmful to us?
Related to "Heat resistance temperature" and melting point?
What is heat resistance temperature?
Heat resistance temperature is the highest temperature at which a material can maintain its structural integrity without deforming or degrading. It is an important property to consider when choosing materials for high-temperature applications.
What factors affect heat resistance temperature?
The heat resistance temperature of a material is affected by factors such as its chemical composition, crystal structure, and the presence of impurities. Additionally, the rate of heating and cooling can also impact a material's heat resistance temperature.
How is heat resistance temperature measured?
Heat resistance temperature is typically measured using techniques such as differential scanning calorimetry (DSC) or thermogravimetric analysis (TGA). These methods involve subjecting a sample to increasing temperatures and measuring the changes in its physical and chemical properties.
What is the melting point of a material?
The melting point of a material is the temperature at which it changes from a solid to a liquid state. It is a characteristic property of a substance and can be used to identify and classify materials.
How does the melting point relate to heat resistance temperature?
The melting point and heat resistance temperature are related in that they both involve changes in a material's physical state due to temperature. However, the heat resistance temperature is typically higher than the melting point, as it refers to the point at which a material can withstand high temperatures without melting or degrading.
  • Classical Physics
  • Materials and Chemical Engineering
43K
