Heat Transfer Coefficient of a circular water duct of rectangular cross section
The discussion centers on calculating the heat transfer coefficient (HTC) for a rectangular duct that is curved in a circular shape. The original poster has found literature on straight ducts and circular cross-section coils but lacks specific resources for their unique configuration. They note that the curvature increases the HTC due to centrifugal forces creating a radial pressure gradient. Participants request clarification on the duct's design, including flow type and aspect ratio, to better assist with the inquiry. The conversation highlights the need for tailored analytical approaches in heat transfer calculations for complex geometries.
Galst
TL;DR Summary
calculation of heat transfer coefficient for round curved square cross section water duct
Hello all, i hope you're having a nice day.
I have a question about analytical heat transfer coefficient (HTC) calculation/determination for a rectangular duct curved in a circle. I have found some literature on this topic and also found empirical equations for rectangular cross section straight water ducts/pipes heat transfer calculation based on dimensions of the duct and also some equations for circular cross section helical pipe coil HTC calculation [1]. But none for my specific problem. I know that with curvature of the pipe/duct, the HTC increases as a result of centrifugal forces inducing radial pressure gradient. Has any of you dealt with something similar in the past? If anyone has any experience or can recommend me some literature for my problem or help me in any other way I would be very grateful.
Best regards!
Gal Štempihar
[1] BERGMAN, Theodore L. Fundamentals of heat and mass transfer. John Wiley & Sons, 2011.
Welcome to PF.
Sorry, can you upload a diagram of this pipe? (Use the "Attach files" link below the Edit window.) I'm having a hard time picturing a "circular water duct of rectangular cross section". Thanks.
Is the flow laminar or turbulent? What is the aspect ratio for the rectangular cross section? What is the radius of curvature of the channel?
Take a length of rectangular tubing, then wrap it around a telephone pole.
(about 80%+ confidence in this description)
p.s. In use, you may want to remove the telephone pole.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
