Heating & Electrical Resistance
In summary: Anisotropic behavior: The physical phenomenon of an object having different properties in different directions.
Jimmy87
686
When you increase the resistance of a filament bulb more work is done on the bulb which means its temperature increases. This causes the ionic lattice to vibrate with a greater amplitude (since it has more kinetic energy). The conduction electrons now encounter more collisions, hence the resistance goes up. What I was wondering is why this does NOT work for a fixed carbon resistor. If you increase the voltage across a fixed resistor it heats up (you can feel it) but the voltage and current remain in direct proportion. What is the reason for this? If a resistor is hot surely the atoms in the carbon resistor are vibrating more (as temperature is proportional to the average kinetic energy)? So how can the resistance not be affected?
nsaspook said:
The resistance is affected by heat in a regular carbon resistor but the change is small compared to a metal like tungsten. One factor is the difference in the collisional process in each material as it heats.
http://hyperphysics.phy-astr.gsu.edu/hbase/tables/rstiv.html
http://www.phy.gonzaga.edu/downloads/phys102L/electricalEquivalent.pdf
Thanks for the help and the links. Do you know what it is specifically about the structure of carbon that makes its resistance remain fairly constant over a wide range of temperatures as appose to tungsten?
I sure others here could give you an exact explanation but I suspect it would have something to do with the anisotropic behavior of carbon expansion in the graphites commonly used in resistors.
http://simscience.org/cracks/glossary/isotropic.html
Likes Jimmy87
Related to Heating & Electrical Resistance
1. What is electrical resistance?
Electrical resistance is the measure of how difficult it is for electricity to flow through a material. It is determined by the type of material, its dimensions, and its temperature.
2. How is electrical resistance measured?
Electrical resistance is measured in units called ohms (Ω). It can be measured using a device called an ohmmeter, which sends a small current through the material and measures the voltage drop across it.
3. What factors affect electrical resistance?
The main factors that affect electrical resistance are the type of material, its dimensions, and its temperature. Materials with high resistivity, smaller dimensions, and higher temperatures will have higher resistance.
4. How does heating affect electrical resistance?
As the temperature of a material increases, its atoms and molecules vibrate more, making it more difficult for electrons to flow through. This results in an increase in electrical resistance. Conversely, as the temperature decreases, the resistance decreases.
5. How is heating used in electrical resistance applications?
Heating can be used to control the electrical resistance of a material. This is commonly seen in devices such as electric heaters or stovetops, where the resistance of the heating element can be adjusted to control the amount of heat produced. Heating is also used in processes like annealing, which can change the properties of a material by altering its electrical resistance.
