Height when a ball is thrown vertically at half its velocity
A baseball thrown vertically reaches a maximum height, h, with an initial velocity, v. To find the height at which the baseball has half its original velocity, it's important to recognize that the calculations should be based on the distance from the ground, not from the peak of the trajectory. The correct approach involves determining the height where the velocity is v/2, rather than calculating distances from the apex where velocity is zero. The calculations provided initially misinterpret the reference level, leading to confusion about the resulting height. Ultimately, the correct height at half the original velocity is 0.75 of the maximum height reached.
Ace.
A baseball is thrown vertically into the air with a velocity, v, and reaches a maximum height, h. At what height was the baseball with one-half its original velocity? Assume no air resistance.
v22 = v12 + 2ad ?
let 10m/s be the original velocity
d = \frac{v^{2}_{2} - v^{1}_{2}}{2g}
d = \frac{0 m/s - (10 m/s)^{2}}{2(-9.8 m/s^{2}}
d = 5.1
at 5 m/s:
d = \frac{0 m/s - (5 m/s)^{2}}{2(-9.8 m/s^{2}}
d = 1.28
\frac{1.28}{5.1} = 0.25
but the answer is 0.75 of the original height. How to solve this?
v22 = v12 + 2ad ?
d = 5.1
at 5 m/s:
d = 1.28
The d you are calculating is the distance between the point where the velocity v=0 and the point where the velocity is v/2. The point where v=0 is at the TOP of your trajectory.
I didn't fully understand what you mean
Ace, in the second part are not using the correct reference level.
The question you should be answering is: if a ball is thrown vertically upwards, at what height above the ground has its velocity dropped back to half of what it initially had?
You are calculating distances from the point where v=0. So the second distance you calculated isn't the distance from the ground. It's distance from the point where v=0. v=0 is at the top of the trajectory.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
