Heine-Porel from Bolzano-Weierstrass
  • Thread starter soopo
In summary, the proof that "Bolzano-Weierstrasse" implies "Heine-Borel" uses the fact that a sequence in a closed and bounded set (or, specifically, [0, 1]) is bounded because the set is bouded, so, by Bolzano-Weierstrasse, contains a convergent subsequence. The fact that the set is closed the implies that convergent subsequence converges to a point in the set and so Heine-Borel.
soopo
225
How can you prove Heine-Porel (unit interval is compact) theorem by Bolzano-Weierstrass theorem (there is a limit in a continuous and bounded interval)?
Compact means that the sequence is complete and totally bounded.
Unit interval perhaps means a bounded interval of an unit length.
I do not see how the continuity in Bolzano-Weierstrass theorem is related to
Heine-Porel theorem.
Hi soopo - disclaimer first as I'm fairly new to this stuff myself
i think the Heine-Borel theorem actually states that a subsapce of Rn is compact iff it is closed & bounded
defintion of compact is for every open cover, there exists a finite subcover
http://en.wikipedia.org/wiki/Open_cover
bolzano theorem states that each bounded sequence in Rn has a convergent subsequence.
http://en.wikipedia.org/wiki/Bolzano-Weierstrass_theorem
so start by assuming you have a closed & bounded set eg. [0,1]. Then try & show its compact... and then the other way.. and how can you relate the Bolzano conditions to the compactness cover defintion & can you find a path between them?
by the way you would have a better chance of getting answered on the calculus part of this forum... Dick & HallsofIvy would rip through it
what "continuity" are you talking about? Bolzano-Weierstrasse says that every bounded sequence of real numbers contains a convergent subsequence. That says nothing about "continuity". I don't understand what you mean by "continuous interval"- it might be a language problem- "connected interval"?
Essentially, the proof that "Bolzano-Weierstrasse" implies "Heine-Borel" uses the fact that a sequence in a closed and bounded set (or, specifically, [0, 1]) is bounded because the set is bouded, so, by Bolzano-Weierstrasse, contains a convergent subsequence. The fact that the set is closed the implies that convergent subsequence converges to a point in the set and so Heine-Borel.
The reason why B-W theorem implies Heine-Borel is that B-W tells us that a closed and bounded set (eg [0, 1]) contains a convergent subsequence.
I have been using a continuous interval as a synonym for a connected interval.
It seems that my convention is false.
Thank you for your reply!
FAQ: Heine-Porel from Bolzano-Weierstrass
What is the Heine-Porel theorem from Bolzano-Weierstrass?
The Heine-Porel theorem states that for any bounded sequence of real numbers, there exists a convergent subsequence. This theorem is a fundamental result in real analysis and is named after mathematicians Eduard Heine and Karl Theodor Porel.
What is the significance of the Heine-Porel theorem?
The Heine-Porel theorem is significant because it guarantees the existence of a limit for bounded sequences, which is a crucial concept in calculus and analysis. It also has important applications in solving optimization problems and proving the convergence of series.
How is the Heine-Porel theorem related to Bolzano-Weierstrass?
The Heine-Porel theorem is closely related to the Bolzano-Weierstrass theorem, which states that a bounded sequence of real numbers has at least one accumulation point. The Heine-Porel theorem is a consequence of the Bolzano-Weierstrass theorem and is sometimes referred to as the "sequential form" of the latter.
Is the Heine-Porel theorem applicable to all types of sequences?
No, the Heine-Porel theorem is only applicable to bounded sequences of real numbers. It does not hold for unbounded sequences or sequences in other metric spaces.
What are some practical applications of the Heine-Porel theorem?
The Heine-Porel theorem has various applications in mathematics and science, such as in proving the existence of solutions to differential equations, analyzing the convergence of numerical methods, and studying the behavior of functions. It also has implications in physics, engineering, and economics.
