Graduate Heisenberg equations of Klein-Gordon Field in Space-Time
The discussion centers on the Heisenberg equations for the Klein-Gordon field, specifically addressing confusion about deriving certain terms in the equations. The first equation is understood, but the second equation raises questions about the disappearance of the factor 1/2 and the integration by parts used to derive the kinetic term. Participants clarify that the Hamiltonian's terms can be manipulated using commutation relations and integration by parts, leading to the Klein-Gordon equations for field operators. Additionally, there are inquiries about resources for better understanding covariant and contravariant tensors in quantum field theory. Overall, the conversation emphasizes the complexities of quantum field theory calculations and the need for clear mathematical derivations.
  • #31
samalkhaiat said:
4) And the most important thing is the following: Since \varphi \mapsto (-1)^{|m|} \partial^{m}\varphi is linear and continuous (from \mathcal{D}(\mathbb{R}^{n}) \ \mbox{into} \ \mathcal{D}(\mathbb{R}^{n})), then (1) can be used to show that the operation of differentiation f \mapsto \partial^{m}f is linear and continuous (from \mathcal{D}^{\prime}(\mathbb{R}^{n}) \ \mbox{into} \ \mathcal{D}^{\prime}(\mathbb{R}^{n})).
I think I know how to show linearity; given the differential operator ##D^{\prime}:\mathcal{D}^{\prime}(\mathbb{R}^{n}) \rightarrow \mathcal{D}^{\prime}(\mathbb{R}^{n}):f \mapsto \partial^{m}f##, we let ##\varphi_1, \varphi_2 \in \mathcal{D}^{\prime}(\mathbb{R}^{n})##, ##\alpha, \beta \in \mathbb{C}## and get
$$D^{\prime}f =\partial^m f$$
Multiplying the above equation both sides by ##(\alpha \varphi_1+ \beta \varphi_2)## (on the right) allows us to use the well-known definition to show linearity
$$D^{\prime}f (\alpha \varphi_1+ \beta \varphi_2) =\partial^m f (\alpha \varphi_1+ \beta \varphi_2)=(-1)^m f\partial^m (\alpha \varphi_1+ \beta \varphi_2)$$ $$=\alpha (-1)^m f\partial^m ( \varphi_1)+\beta (-1)^m f\partial^m ( \varphi_1)=\alpha f(\varphi_1)+\beta f(\varphi_2)$$
Where I've used the fact that ##D:\mathcal{D}(\mathbb{R}^{n}) \rightarrow \mathcal{D}(\mathbb{R}^{n}):\varphi \mapsto (-1)^{|m|}\partial^{m} \varphi## is linear.
Argh I'm having trouble to show continuity though.
  • #32
Are you studying some particular book/notes or just post in this thread? I may have missed it, but what continuous means for distributions wasn't said in this thread.
  • #33
Hi martinbn
I was trying to show what samalkhaiat wrote here
I showed linearity but got stuck in showing continuity.
  • #34
JD_PM said:
Hi martinbn
What does it mean to be continuous?
  • #35
samalkhaiat said:
3) A distribution (or generalized function) f is a continuous functional on \mathcal{D}(\mathbb{R}^{n}). That is, if \varphi_{k} \to \varphi as k \to \infty in \mathcal{D}(\mathbb{R}^{n}), then (f , \varphi_{k}) \to (f , \varphi ) as k \to \infty.
  • #36
In short, distribution is a continuous linear functional on the spaces of “nice” functions.
And what does \varphi_{k} \to \varphi as k \to \infty mean?
  • #37
Honestly I still do not completely get it either 😬
  • #38
My point was, if you have not even seen the definition how do you expect to understand or prove the continuity!?
  • #39
JD_PM said:
##\mathcal{D}(\mathbb{R}^{n})## is the vector space of operators ##\varphi: \Bbb R^n \rightarrow \Bbb R^n## having the following two properties: 1) ##\varphi## is smooth and 2) ##\varphi## has compact support.
\mathcal{D}(\mathbb{R}^{n}) is the space of all infinitely differentiable functions \varphi : \mathbb{R}^{n} \to \mathbb{R} with compact support. The support \mbox{supp} \ \varphi (x) of a function \varphi(x) is the closure of the set on which \varphi (x) \neq 0.
Mmm I've got a little doubt here: you said ##(f,\varphi)## is a complex number, but as we're dealing with ##L_f:\mathcal{D}(\mathbb{R}^{n}) \rightarrow \Bbb R## it would make more sense to me that ##(f,\varphi) \in \Bbb R## but of course I may be missing something really evident here).
No, that is a classic misunderstanding. When we turn the set \mathcal{D}(\mathbb{R}^{n}) into a vector space over the field of complex numbers, the elements of \mathcal{D}(\mathbb{R}^{n}) become complex-valued functions of the real variables x = (x^{1}, \cdots , x^{n}) in the open set \mathcal{O} \subset \mathbb{R}^{n}. Let \alpha and \beta be two complex numbers and write \varphi = \alpha \varphi_{1} + \beta \varphi_{2}. Now, is the number (f , \varphi ) real or complex?
For a locally integrable function f(x), the functional F_{f} [\varphi] \equiv (f , \varphi) = \int d^{n}x \ f(x) \varphi (x) is linear in that, if \varphi_{1} and \varphi_{2} are in \mathcal{D} and if \alpha and \beta are two (real or complex) constants, then F_{f}[\alpha \varphi_{1} + \beta \varphi_{2}] = \alpha \ F_{f}[\varphi_{1}] + \beta \ F_{f}[\varphi_{2}].
Likes JD_PM and dextercioby
  • #40
JD_PM said:
OK the idea I have in mind is showing that we get the same result either using ##\partial^{k} \left( \partial^{m}f \right)## or ##\partial^{m} \left( \partial^{k} f \right)##
When ##\partial^{k} \left( \partial^{m}f \right)## we get
$$\int dx \ \partial^{k} \left( \partial^{m}f \right) \ \varphi (x) = \partial^{k} \left( \partial^{m-1}f \right) \ \varphi (x) -\int dx \partial^{k} \left( \partial^{m-1}f \right) \ \partial \varphi (x)$$
Applying integration by parts ##m## times one gets
I am afraid that was garbage. For \varphi \in \mathcal{D}, use the following equalities \partial^{r + s} \varphi = \partial^{r}(\partial^{s}\varphi) = \partial^{s}(\partial^{r}\varphi) , integrate with f \in \mathcal{D}^{\prime} and multiply the equalities with (-1)^{r + s}: (-1)^{r + s} (f , \partial^{r + s} \varphi ) = (-1)^{r + s}(f ,\partial^{r}(\partial^{s}\varphi) ) = (-1)^{r + s}(f , \partial^{s}(\partial^{r}\varphi) . Now, use our definition (1) once on the left-hand-side and twice in the middle and the right-hand sides. This gives you (\partial^{r + s}f , \varphi ) = ( \partial^{s}(\partial^{r}f) , \varphi ) = (\partial^{r}(\partial^{s}f) , \varphi ). QED.
Likes dextercioby
  • #41
:smile:
The functional F_{f} [\varphi] is continuous in the following sense: Consider a sequence of functions \{ \varphi_{k}(x) \} in \mathcal{D} (\mathbb{R}^{n}) with the following two properties:
1. There exists a compact set K \subset \mathbb{R}^{n} such that for all k, \mbox{supp}\ \varphi_{k} \subset K.
2. \lim_{k \to \infty} \partial^{m}\varphi_{k}(x) = 0 uniformly for all m = 0, 1, 2, \cdots.
Such a sequence is said to go to 0 in \mathcal{D} and is written \varphi_{k} \to 0, \ k \to \infty in \mathcal{D}.
We then say that the functional F_{f}[\varphi] is continuous if F_{f}[\varphi_{k}] \to 0 for \varphi_{k} \to 0, \ k \to \infty in \mathcal{D}.
Let us discuss this definition of continuity of linear functionals on the space \mathcal{D}. Continuity is a topological property. The space \mathcal{D} is a linear vector space. It is made into a topological vector space by defining the neighbourhood of the “point” \varphi (x) = 0 by a sequence of semi-norms. One can show (and that one is definitely not you) that the two conditions required above in the definition of \varphi_{k} \to 0 in \mathcal{D} follow from the conditions used to define the neighbourhood of \varphi(x) = 0. The definition of continuity of linear functional on \mathcal{D} can then be based on the weak or strong topologies of space \mathcal{D}^{\prime}. It so happens that the definitions of continuity based on these topologies are equivalent to the above definition of F_{f}[\varphi_{k}] \to 0 if and only if \varphi_{k} \to 0 in \mathcal{D}. Furthermore, since \mathcal{D} is a linear space, we can define \varphi_{k} \to \varphi , \ k \to \infty in \mathcal{D} if (\varphi_{k} - \varphi ) \to 0, \ k \to \infty in \mathcal{D}, and because F_{f}[\varphi] is linear, we can also say that F_{f} [\varphi] is continuous on \mathcal{D} if when \varphi_{k} \to \varphi, we have F_{f} [\varphi_{k}] \to F_{f} [\varphi].
Now, if you have digest the above, proving that f \mapsto \partial^{m}f is continuous from \mathcal{D}^{\prime} into \mathcal{D}^{\prime} is “easy”. First, recall our definition (\partial^{b}f , \varphi ) = (-1)^{|m|} (f , \partial^{m}\varphi ) . \ \ \ \ \ \ \ \ \ \ \ \ \ \ (1) Since \varphi \mapsto (-1)^{|m|}\partial^{m}\varphi is linear and continuous, the functional \partial^{m}f defined by the right-hand-side of (1) is a generalized function in \mathcal{D}^{\prime}(\mathbb{R}^{n}), i.e., the derivative of a distribution is also a distribution. Now, suppose f_{k} \to 0, \ k \to \infty in \mathcal{D}^{\prime}(\mathbb{R}^{n}). Then for all \varphi \in \mathcal{D}(\mathbb{R}^{n}) we have (\partial^{m}f_{k} , \varphi ) = (-1)^{|m|} (f_{k} , \partial^{m}\varphi ) \to 0, \ k \to \infty , meaning that \partial^{m}f_{k} \to 0, \ k \to \infty in \mathcal{D}^{\prime}(\mathbb{R}^{n}). QED
  • #42
samalkhaiat said:
3) Given a generalized function f \in \mathcal{D}^{\prime}(\mathbb{R}^{n}) and a good function a \in C^{\infty}(\mathbb{R}^{n}), how do you know that the Leibniz rule holds for the differentiation of the product af? You don’t. But, if you use the definition (1), you can show that \partial^{m}\left( af \right) = \sum_{k \leq m} \begin{pmatrix} k \\ m \end{pmatrix} \ \partial^{k}a \ \partial^{m - k}f .
To properly answer this, first let's set up the proper definitions so everything checks out latter.
Let V be a vector space over the scalar field F which can be either \mathbb{R} or \mathbb{C}. Given two elements of V such as u, v \in V be elements of V, then we define the inner product as map
$$(.,.): V \times V \to F$$
$$ u, v \to (u, v) \in F$$
such that it satisfies the following properties:
1. Conjugate symmetry:​
$$(u, v) = (u, v)^{*}$$
where the notation means that given z \in \mathbb{C}; then z^{*} is just the complex-conjugate of z.​
2. Linearity in the first argument:​
$$\alpha, \beta \in F; \quad u, v, b \in V; \quad (\alpha u + \beta v, b) = \alpha(u, b) + \beta(v, b)$$
3. Positive definite:​
$$(x, x) \ge 0 \quad \forall x \in V \setminus \{0\}$$
Now, let \mathcal{D}(\mathbb{R}^n) be the vector space over the field \mathbb{R} (if it was over the field \mathbb{C}, then we'd say \mathcal{D}(\mathbb{C}^n)) such that its elements are "nice" functions \varphi :\mathbb{R}^n \to \mathbb{R}. We say that a function is "nice" if:
  1. It's smooth
  2. It has compact support
And finally, given f, g \in \mathcal{D}(\mathbb{R}^n), we take the our inner product to be:
$$(f, g) := \displaystyle\int d^n x \bigg( f(x) g(x) \bigg)$$
With all this in place, we can finally define a "distribution". If V = \mathcal{D}(\mathbb{R}^n) and V^{*} is its dual space, then T_f \in V^{*} is a linear form such that if f, \phi \in V are nice functions, then \quad T_f[\phi] = (f, \phi) \in \mathbb{R}. We call T_f a "distribution", but usually we abuse the notation by calling f itself the distribution. Because of that, it is desirable to define the derivative of a distribution such that \partial (T_f) = T_{\partial f}. Using integration by parts and the fact that the nice functions have compact support:
$$(\partial f, \phi) = \displaystyle\int d^n x \bigg( \partial f(x) \phi(x) \bigg) = \cancel{\bigg[ f(x) \phi(x) \bigg]_{-\infty}^{\infty}} - \displaystyle\int d^n x \bigg( f(x) \partial \phi(x) \bigg) = -(f, \partial \phi)$$
$$\implies T_{\partial f}[\phi] = -T_{f}[\partial \phi]$$
From now on we'll abuse the notation too and refer to the distribution T_f just as f.
Now, before proving the statement, I would like to point out that there's an error in the binomial number that you've written there, the m and k are swapped. I think the correct formula is:
$$\partial^{m}\left( af \right) = \sum_{k \leq m} \begin{pmatrix} m \\ k \end{pmatrix} \ \partial^{k}a \ \partial^{m - k}f = \sum_{k = 0}^m \begin{pmatrix} m \\ k \end{pmatrix} \ \partial^{k}a \ \partial^{m - k}f$$
based on what I see on wikipedia here.
Anyway, let's begin with the proof:
We'll first prove that the distribution f satisfies the Leibniz rule as usual \partial(af) = (\partial a) f + a(\partial f) . Then the proof for the given formula for a function a and a functional f is the same as it would be for two functions.
Let f(x), \varphi(x) \in V be nice functions and f be a distribution. Also let \varphi(x) = a(x) \phi(x) where a, \phi \in V. We'll understand that when we write f(x) we refer to the function and when we write f or f[.] we refer to the distribution.
$$f[\varphi] = (f(x), \phi(x)) = \displaystyle\int d^n x \bigg( f(x) \varphi(x) \bigg) = \displaystyle\int d^n x \bigg( a(x) f(x) \phi(x) \bigg) = $$
$$ = \displaystyle\int d^n x \bigg( [a(x) f(x)] \phi(x) \bigg) = (af)[\phi] \equiv g[\phi]$$
where we have defined the distribution g as af and the function g(x) := a(x)f(x). Now
$$(\partial f, \varphi) = \displaystyle\int d^n x \bigg( \partial f(x) \varphi(x) \bigg) = -\displaystyle\int d^n x \bigg( f(x) \partial\{ a(x) \phi(x) \} \bigg) = $$
$$= -\displaystyle\int d^n x \bigg( \partial a(x) f(x) \phi(x) \bigg) -\displaystyle\int d^n x \bigg( g(x) \partial \phi(x) \bigg) = -(\partial a(x) f(x), \phi(x)) -(g(x), \partial \phi(x))$$
$$(\partial f, \varphi) = \displaystyle\int d^n x \bigg( \partial f(x) \varphi(x) \bigg) = \displaystyle\int d^n x \bigg( [a(x) \partial f(x)] \phi(x) \bigg) = (a(x)\partial f(x), \phi(x))$$
$$(a\partial f)[\phi] = -(\partial af)[\phi] - g[\partial \phi] = -(\partial af)[\phi] + (\partial g)[\phi] \implies$$
$$\implies \bigg( \partial(af) \bigg) = \bigg( (\partial a) f \bigg) + \bigg(a(\partial f) \bigg)$$
and so we've proven that distributions obey the Leibniz rule.
Q.E.D.​
And so, because distributions behave the same way under differentiation as functions do, you can copy-paste the proof for the formula
for a and f being functions (which is trivial) into the one where they are distributions; thus proving the formula for distributions as well.
You can check that proof here.
  • · Replies 24 ·
