Helical conical compression spring design
The discussion centers on designing a helical conical compression spring with a constant pitch and round wire cross-section, focusing on determining the pre-compressed geometry needed to achieve a specific final shape upon compression. The user notes that compressing the spring without torque results in a decrease in the number of turns and an increase in the diameter of each turn. They seek equations to calculate the angular deflection due to axial loading, particularly with both ends free to rotate, and consider approximating the conical spring as a series of regular compression springs. Material properties are acknowledged as relevant for compression force calculations but not explicitly for geometry. The user aims to refine their approach to achieve the desired spring characteristics effectively.
jstluise
I am designing a constant pitch, helical conical compression spring (round wire cross section) that will be compressed into a final desired shape. So my issue at hand is figuring out the pre-compressed geometry that will give me my desired final geometry once compressed.
The compression will be accomplished by longitudinal tension lines (fixed at each point on the spring for constant pitch), so the spring should not be torqued at all when compressed. As opposed to keeping the two end orientations fixed when compressing.
I have a spring I've been playing with, and my observations are that when the spring is compressed (with no torque), the number of turns decreases and the diameter of each turn increased.
I've been unsuccessful so far in finding equations to help me figure this out...
Final Shape, Known:
Dmin - small diameter, bottom of spring
Dmax - large diameter, top of spring
N - number of turns
h - height
L - total arc length, function of other variables, remains constant
Uncompressed Shape:
Dmin0 - Unknown
Dmax0 - Unknown
N0 - Unknown
h0 - Known, based on the compression I want (~50%)
L0 = L
Can anyone shed some light on this? I'm not sure if material properties come into play...I know they will for the compression force required, but I don't know about the geometry.
Thanks!
The formula for conical springs is based on ordinary compression springs ie for each turn on the conical spring
here are some formula :-the rate for each individual turn or
fraction of a turn = k=Gd^4/(8*D^3*Na)
total rate k for a complete spring
of different diameter turns = k= 1/((1/k1)+(1/k2)etc)To calculate stress in the wire the mean diameter of the
largest active coil is used at the required load ie:-
S= 8*P*D*Kw/(3.142*d^3)
The solid height of a conical spring of a uniform taper but not telescoping, with squared and ground ends can estimated
La=Na*(d^2-u^2)^0.5 + 2d
where G= modulus of rigidity of material
d= wire dia
D= mean coil diameter
Na = number of active turns
k = spring stiffness
S = stress
P= spring load
La= solid height of spring
u = o.d of large coil - o.d. of small coil/(2*Na)
Kw1= (4*C-1/(4*C+1))+ 0.615/C
C = mean dia of largest coil/ wire diameter
Thanks for the response, but that is not quite what I am after. Basically I am looking for an equation for angular deflection due to axial loading (ie change in height) with both ends free to rotate.
I'll focus my search on finding it for a regular (non-conical) compression spring, then I can separate my conical spring into several compression springs in series. My taper angle is pretty low, so that should give me a good approximation.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
