Help, apple falling/conceptual problem
  • Thread starter 4.19mile
  • Tags
    apple
In summary, the Earth's rotation does not have a significant effect on an apple that is dropped from a tree. The apple will move with the Earth as it rotates and will fall back to almost the same spot it was dropped from, similar to throwing a ball into the air. This was a conceptual problem on a review worksheet for an upcoming final exam.
4.19mile
How does the Earth's rotation affect an apple that is dropped from a tree?
None
Er... I'm not 100% sure on this one =/. Does it pull on it as it falls down or something? Help would be MUCH, much appreciated, thank you!
Help?
How does the apple move relative to the earth? I mean when the Earth spins does the apple move with the Earth or does it stay put while the Earth revolves?
I'm not sure, that was just one of the conceptual problems on the worksheet we got for reviewing the last few chapters (since finals are coming up) =/
Well turns out that the apple isn't effected in the normal sense. The apple moves with the earth. I mean if you throw a ball up it comes back down in almost the exact spot you threw it into the air, the same applies to the apple.
Related to Help, apple falling/conceptual problem
1. What is the concept behind the falling apple problem?
The falling apple problem, also known as the apple falling problem or the apple concept problem, is a thought experiment used to illustrate the concept of gravity. It involves imagining an apple falling from a tree and questioning why it falls towards the ground instead of floating away.
2. Who first proposed the falling apple problem?
The falling apple problem was first proposed by Sir Isaac Newton in the 17th century. He used this thought experiment to develop his theory of gravity and to explain the motion of objects in the universe.
3. What does the falling apple problem teach us about gravity?
The falling apple problem teaches us that gravity is a force that pulls objects towards each other. In this case, the apple falls towards the Earth because of the force of gravity between the Earth and the apple.
4. How does the falling apple problem relate to Newton's laws of motion?
The falling apple problem is closely related to Newton's laws of motion. It illustrates the first law of motion, which states that an object at rest will stay at rest and an object in motion will stay in motion unless acted upon by an external force. In this case, the apple stays at rest until the force of gravity pulls it towards the ground.
5. What other concepts can be learned from the falling apple problem?
The falling apple problem can also teach us about acceleration, mass, and inertia. It demonstrates that the acceleration due to gravity is constant and does not depend on the mass of the object. It also shows that objects with greater mass have greater inertia and require more force to move them.
