Help finding coefficient of friction
The discussion revolves around calculating the minimum coefficient of static friction required for a 1600kg car on a 16-degree ramp. The user consistently arrives at a coefficient of 0.395, while the textbook states it should be 0.365. The user provides their free body diagram and equations for forces and moments, leading to values for normal force and friction force. Despite following the equations, the user is uncertain about where their calculations diverge from the textbook answer. Clarification on the correct approach or identification of errors in the calculations is sought.
Soshamim
Hey, I was wondering if someone could help me with this statics problem.
The question is: "The 1600kg car is just beginning to negotiate the 16* ramp. If the car has rear-wheel drive, determine the minimum coefficient fo static friction required at B.
My FBD:
The answer I keep getting is 0.395, but the book says Us = 0.365.
I'm about to type up my work in a second
\Sigma \vec{F}_{x} = \vec{f}_{B} - \vec{A} sin(16) = 0
\Sigma \vec{F}_{y} = \vec{B} + \vec{A} cos(16) - G = 0
\Sigma \vec{M}_{B} = -1.475*G + 2.545*\vec{A} cos(16)
...From moment equation, A = 9463N
...From Fy equation, B = 6599N
...From Fx equation, Fb = 2608N
Using Fb = u*B, I get u = 0.395, which is not the correct answer. I'm not really sure what I'm doing wrong here.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
