Help finding distance using work and velocity
The discussion centers on calculating the distance a ski jump should be placed based on a skier's mass, initial velocity, and frictional forces. The work-energy theorem is applied to relate the skier's initial and final kinetic energy, accounting for energy lost to friction. Participants emphasize the importance of considering gravitational potential energy as the skier descends, which converts to kinetic energy while also factoring in frictional losses. Correctly managing the signs in the energy equations is crucial for accurate calculations. The conversation concludes with the participant feeling more confident in their understanding of the problem.
Salacious Crumb
I'm looking to the distance (h) a ski jump should be placed from the top of the hill so that a skier with a mass of 85kg will not exceed 30.0m/s. I am given an initial velocity of 2.0m/s and the total work of frictional forces to 4000J
How can I use total work to determine distance with the variables I'm given? I'm not looking for the answer I just need to be pointed in the right direction here.
I used the work-energy theorem W(total) = Kinetic (final) - Kinetic(initial)
Kf = 1/2mv^2 = 1/2 * 85kg * (30.0m/s)^2 = 38250J
Ki = 1/2mv^2 = 1/2 * 85kg * (2m/s)^2 = 170J
Wtotal = 38250 - 170 = 38080J
subtract the frictional energy of 4000J
34080J and this is where I'm stuck. Honestly I don't even know if I'm on the right track.
Hi SC, Welcome to Physics Forums.
A question is not a relevant equation. Questions should go in the problem statement. You should list equations you believe may be relevant to the type of problem being solved in the relevant equations section.
Before tackling the details of a problem like this it's a good idea to list all the places where energy is coming from or going. You've recognized the initial KE, final KE, and the frictional force losses. What other form of energy is in play here? When a skier descends a mountain, why does he gain speed?
Sorry, I guess I skimmed over that too quickly. I read it as questions.
The skier accelerates due to the vector of the gravitational force working along the slope of the hill.
So the potential energy (U) of the skier is transformed to K as he moves down the slope.
Kf - Ki = Uf - Ui + Efric -> Kf - Ki = mg(Yf - Yi) + Efric Yf-Yi is h
Am I on the right track now?
Yes, that's the idea. As the skier descends he trades gravitational PE for KE, but also loses KE to friction.
Make sure that you get your signs right to reflect gains or losses. For example, if the skier starts at the top of the hill at height Yi and ends lower down at height Yf, then mg(Yf - Yi) is going to be negative. While it's true that he's losing gravitational PE, his KE should be increased by this amount. Just spend a bit of time making sure that the signs you give the terms reflect what's taking place.
Thank you for your help, I think I have it.
Great! Glad to help.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
