member 745317
- TL;DR Summary
- Corrosion due to mixing chlorine and copper sulfate.
This must be the dumbest thing I have ever done. I used copper sulfate (CuSO4) for an experiment. I first bought copper sulfate in crystalline form and then mixed it in water. After the experiment was done I flashed the copper sulfate down the toilet but some of it was actually absorbed by the porcelain. After a couple of hours I threw the usual amount of chlorine into the toilet, completely unaware of what would happen next. You probably guessed it: the porcelain has been dissolved and there is nothing I can do about it. The problem is the copper sulfate is still stuck inside of the porcelain, so if I keep adding chlorine the damage will become worse. Is there any solution to this?
