I Help identifying this Tumbling object in a night sky photo from Namibia
A night sky photo taken in Namibia shows an object with a strange trajectory, prompting discussions about its nature. The object may be a high-altitude aircraft exhibiting a zig-zag pattern due to autopilot oscillations, or potentially a tumbling satellite or rocket stage. Observers note that the object's light pattern differs from typical airplane tracks, suggesting it could be a reflective, rotating object. The lack of specific details about the photo, such as time and location, complicates identification. Ultimately, the object remains unidentified, with possibilities ranging from aircraft to celestial phenomena.
timmdeeg
TL;DR Summary
Question: What tumbling object causes this trajectory?
I have received this image from someone in Namibia recently at the Kiripotib Astrofarm.
Has anyone an idea what could cause such a strange trajectory?
Astronomy news on Phys.org
If we had the exact time, location and direction we could probably identify it unless it was an airplane (so, exposure and focal length too).
Why do you say "tumbling", which implies rotation. Is there something I am missing?
timmdeeg said:
TL;DR Summary: Question: What tumbling object causes this trajectory?
The line in the top right is a satellite track. It shows that the telescope was steady, and the stars show it was tracking.
The partial track could be a high altitude aircraft, flying on autopilot through disturbed air with variable crosswinds, which explains the wandering. It appears to have a strobe light that marks a series of dots along its path.
Likes FactChecker and russ_watters
Hosea Kutako International Airport, Windhoek, Namibia, is overflown by international flights between Capetown and Western Europe, and between Johannesburg and the East Coast USA.
Likes russ_watters
Are you on a small screen? If so you'll need to zoom in quite a bit to see that the track is jagged. Something corkscrewing along doesn't seem implausible as an a priori explanation for it.
I am visually impaired, yes. But the word "tumbling" implies rotation, and not a a jagged path. There are probably thousands of asteroids that are tumbling in perfectly elliptical orbits.
I have made hundreds of such photos myself (for astrophotography) and never saw anything comparable.
Lights of airplanes show parallel tracks, whereas "amplitude" and "wavelength" of this curve are quite constant which seems to indicate that something rotates. But if correct this would require that the object reflects/emits light apart from its center of mass. The satellite track above (photo OP) is much more faint which could indicate, that this object is much closer. - Also very weird, the object suddenly becomes visible without transition.
a crop
  • Wow
Likes pinball1970 and phinds
What do you mean by that?
We do not know which way it travelled. The end of the track on the image could be the start or end of the camera exposure, or entry or exit from the Earth's shadow, or they might have just turned the light off. How can we be sure it is not a computer modified fake image, designed to waste our time?
We have no idea of the details of the image. Photographer, date, time window of exposure, lat/lng of observatory, RA/Dec of telescope, magnification, is North Up, identity of three bright stars in the field?
The obvious observation is that it must remain a UFO, until you can provide sufficient details to make identification possible.
Likes russ_watters and phinds
I would not call that "tumbling". I would simply call it "rotation".
I would restrict the word "tumbling" to motion about a body's intermediate principal axis. Unlike the other two axes, this is unstable. I don't see that here. I don't see anything that can't be explained by a spinning object that is more reflective in parts,
Yes agreed. It is as if a rotating lengthy object reflects light at one end quite uniformly.
@Baluncore I know the person from whom I have got this the image, no doubt about seriousness. North is up.
Such lightframes as we call them show about one to some degrees of the sky depending on the focal-length of the scope. Of course I could ask for more details, e.g. date, exposure time ... but don't think that would help to resolve the puzzle.
EDIT Something else, looking at the first image: if one follows the track down to the left, the amplitudes are decreasing for some "wavelengths", then increasing and below decreasing again.
Calling them "tumbling" is a thing and not worth the quibble vs "rotating", but they don't usually look like that. Usually they are just linear dashes. See:
https://www.satobs.org/tumble/tumbleintro.html
It would need to be a very large satellite for it to look like zig-zagging unless it is at very high magnification.
I was thinking meteor rather than satellite.
Which would make me think it is relatively close. However, from a single observation it is most likely impossible to identify unless a candidate can be found. A rocket launch with a discarded "tumbling" stage for example.
Regards Andrew
Oh it's much more wibbly-wobbly* than I thought!
  • Its large-scale path is not straight; it wobbles side-to-side (see long reference line).
  • And its small-scale path is (inasmuch as the resolution will allow) not consistent (see short ticks, lower right).
*technical term
I would suggest that
  • the side-to-side wobble is also periodic:
And, for the record, the satellite track in the upper right corner shows that none of the wobbles are camera artifacts:
My vote goes with @Baluncore 's post #4 -- an airplane on autopilot with blinking strobe lights. There appears to be some oscillation in the autopilot system.
Likes russ_watters
I don't see how that would produce this zig-zag:
It does not appear to be merely the on/off of a strobe light. It's continuous, and it oscillates side-to-side.
It really appears to me to be a complex spiral.
Two lights; one on, one flashing, not quite on the same line.
I agree the airplane explanation is most likely.
Likes DaveC426913
If we knew the magnification, or star identification, we could evaluate the angular dimensions, so linear size of an aircraft at 36,000 ft, or a long rocket body in LEO.
What is the period in time of the pattern in the image?
Aircraft have strobe lights on wingtips and tail. There are also less bright continuous beacon lights on all flying aircraft. When you cannot see the light source directly, the skin of the aircraft or the contrail(s), may be illuminated by the continuous beacons or strobes.
The strobes now have accurately fixed rates, but often alternate, so are not synchronised. Boeing and Airbus employ different individual strobe systems, Boeing use equal spaced single pulses, Airbus often have a regular double pulse from each strobe, that is easier to follow at a distance.
Likes russ_watters
Perhaps I can obtain some more details.
From time to time I have an aircraft, but being deleted I can't show such an image. The main impression is straight lines in different colors and bigger in size.Here some stars HD.... from astrometry.net
  • Love
Likes DaveC426913
Wow! You found it!
It is a very teeny section of the sky. So small I cannot show it and its context in the same pic.
Maybe somebody can work out the length of that path thats visible. It's tiny, on the order of a degree.
Here it is with Equatorial Coords (those are the ones that are time-agnostic, right?).
I'm not sure where to take this next. We still don't know what time or season this is.
Baluncore said:
If we knew the...
[correction on my first post] If we knew the time and location the photo was taken we could identify the exact plane, too, if it is one.
Oh my goodness. 💡
There are fireflies in Africa.
And there are fireflies that pulse rather than flash.
Butterfly effect, but with fireflies?
  • Haha
Likes DaveC426913
I still wonder whether rotation could clarify this issue.
Lets assume we look at the rotational plane which is stabilised by gyroscopic forces. And further that a part of the object reflects sunlight, then depending on its speed and its rotational frequency such a track could result. - If so then the rotation period should be deducible from track details and the exposure time 181s.
Here are the data, hopefully helpful.
IMG_2152.CR2 10.Aug.2023 23:43
Maße: 2592 x 3888
Dateigröße: 11,6MB (12.130.712)
Kameramarke: Canon
Kameramodell: Canon EOS 1000D
Blendeneinstellung: F0
Blende: Finf
Brennweite: 1000 mm
Belichtungszeit: 181 s
Belichtungskorrektur: 0 EV
ISO-Empfindlichkeit: 1600
Urspr. Dat./Uhrz.: 10.08.23 23:43:05
Datum/Uhrz. digital: 10.08.23 23:43:05
Weißabgleich: Manual
Belichtungsmessung: Multi-segment
Blitz: No, compulsory
Belichtungsprogramm: Manual
Belichtungsmodus: Manual
Farbraum: sRGB
Ausrichtung: right, top
x-Maße in Pixel: 3888
y-Maße in Pixel: 2592
x-Auflösung: 72
y-Auflösung: 72
Auflösungseinheit: inch
N 50° 30' 0.00" E 7° 31' 36.97"
That is near Koblenz, between Cologne and Frankfurt in Germany.
Frankfurt, air-traffic central for Germany.
What a wild goose chase this has become. We are wasting our time.
Likes sophiecentaur, Vanadium 50 and russ_watters
I think the photo is from Namibia, but the OP is from Germany. And it appears the OP is just dabbling with their locale in a hypothetical exercise.
I got this image, which shows two stars on the track, not hidden by something. Not sure if this is of any help.
  • #31
Is this a blow up from the same pic or is this a different photo?I am now really liking Devin-M's firefly hypothesis. It explains the track artifacts even better than the 'airplane lights' hypothesis.
  • #32
Old satellites that have lost inertial control inevitably start to tumble. If they are geostationary satellites, we see them during the equinoxes as flashes of lights as some reflective, flat surface catches the sunlight and strobes across our location. Closer satellites produce a flashing track just like the OP posted.
It could also be a spinning&tumbling booster from a recent launch.
  • #33
I'm sayin' this latest pic pretty much rules out any undirected cause (i.e. it's gotta be living thing).
(well, I s'pose a rocket booster that got winged by a meteor at the exact right time couldn't be completely ruled out).
  • #34
Tumbling boosters look like that. Spinning, tumbling and precessing.
  • #35
Do they spontaneously stop tumbling mid-path?
(Insert obligatory T-wrench video here
Likes chemisttree
  • #36
Sorry my English isn't so good. What is a tumbling booster? Part of a rocket?
  • #37
Bur this is a long-time exposure. Most of the time the object is not blocking the stars.
Frankfurt aspires to be as confusing as Heathrow, but only manages to be as bad as Pearson.
And if we mean "rotate" we should say "rotate" and not "tumble".
Likes russ_watters
  • #38
Yes
  • #39
Just my curiosity but I don't understand why the term "tumbling" has met with so much objection.
Is it a technical term I am not aware of?
Because 'apparently rotating, uncontrolled, on multiple axes' seems to be quintessentially 'tumbling' where I come from.
In fact, "rocket boosters" and "tumbling" seems to be not uncommon phraseology on NASA (number #2 Google hit) and other rocket-centred sites:
  • #40
The unstable motion of a body rotating about its middle axis is called "tumbling".
  • #41
“Unstable” is implied when using “tumble.”, yes?
  • #42
If it’s a satellite, what’s the minimum plausible deflection length of the reflection? If it’s 350 miles away, 100 ft long, how many pixels is that?
  • #43
I think 100 ft at 350 miles is 0.00309 Degrees or 11.1 arc seconds (a little more than half the apparent size of Saturn viewed from Earth). What’s the arc second per pixel on the telescope? I think with a Nikon D800 36MP sensor full frame on a 2175mm focal length scope I get theoretically 0.46 arc sec per pixel. That could conceivable lead to a 24 pixel wobble (12 pixel each direction side to side) from centerline of trajectory.
Devin-M said:
Saturn:
  • #44
It would be traveling 7800 m/s… if it’s 30 meters long it’s covering 260 body lengths per second. At what RPM would it need to be rotating to match the observed curve? Would it be able to withstand those centrifugal forces?
  • #45
Perhaps a cylindrical object that is reflective only on one end?
  • #46
Sorry for being absent for some time.
This I have been thinking too, but the explanation seems much different after some discussion with a former astronomer at the university of Heidelberg.
There are two traces, a broad one like a snaky line and above a thin one which ist straight. Imagine a vibration of the mount (which I have never experienced myself though) and that both lines originate from satellites. But why then snaky and straight?
The duration for satellites to go through the image section is about seconds (remember 1000 mm focus length). Now two assumptions: First, the satellite above (straight line) went through after the satellite below. Second, the mount vibration was finished before the above satellite went through. Indeed the amplitude of the snaky line is decreasing at the lower side of the line, before passing through.
Why the broad line? It seems it can be shown that's due to a very rapid satellite motion/tumbling.
Please let me know in case above conclusions are not consistent.
This issue will be most probably be discussed in the magazine "Sterne und Weltraum". I'll keep you informed.
  • #47
You can estimate the minimum body lengths per second (assuming it’s orbital) and from this the rpm— I suspect it’s quite high. If it comes out to 10 revolutions per second or more is that still plausible? If we try putting a rocket booster on a turntable at 100 revolutions per second (6000rpm) I think it flies apart.
  • #48
There's an awful lot to look through here but has anyone determined the possible speeds of the object, given the angle traversed in 3 minutes(?) and the likely radius of rotation?. I'd bet it's a small, slow object. I remember being fascinated by what turned out to be a sky lantern - in the early days before they were popular. My distance perception suggested it was massive and very fast when it was actually just across the valley from me and drifting by on a light wind.
  • #49
I think telescope wobble for part of the exposure can be ruled out because the other stars are round.
  • #50
This is a crop from which I roughly calculate the amplitude of the curved line to be 15 arc s using the Astrometry.net data below. This shouldn't be a problem with Autoguiding.
Center (RA, Dec):(312.617, 31.896)
Center (RA, hms):20h 50m 28.049s
Center (Dec, dms):+31° 53' 45.233"
Size:18.8 x 19.5 arcmin
Radius:0.226 deg
Pixel scale:0.796 arcsec/pixel
Orientation:Up is 88.2 degrees E of N
15K
