Help in derivation on a trig function in dipole radiation.
The discussion focuses on deriving the electric dipole potential, specifically the expression for the cosine term in the context of dipole radiation. The key point is the approximation of the cosine function when the distance between charges (d) is much smaller than the distance to the field point (r). Participants explore the use of the Law of Cosines and the Binomial theorem to simplify the expression for η+, leading to the desired form of the cosine term. The conversation highlights the challenges in achieving the correct factor of two in the derivation and seeks clarification on the Binomial theorem's application in this context. Overall, the thread emphasizes the mathematical intricacies involved in dipole potential calculations.
yungman
This is part of derivation of electric dipole potential where:
V(\vec r,t)=\frac 1 {4\pi \epsilon_0} \left [ \frac {q_0 cos [\omega(t- \frac {\eta_+} c )]}{\eta_+}- \frac {q_0 cos [\omega(t- \frac {\eta_- } c)]}{\eta_-} \right ]
\vec {\eta_+} = \vec r - \vec r^+ (t_r) \;,\; \eta =\sqrt{r^2+(r^+) ^2}
Where r points to the field point where V is measured and \vec r^+ (t_r)\; is position of the positive point charge. \vec {\eta}_+ (t_r)\; is the vector from positive charge to field point. There is of cause a \vec {\eta}_- (t_r)\; for the negative charge also.
For d<< r, The book claimed without proof that:
cos [\omega(t-\frac {\eta_+} c)] = cos \left [\omega(t-\frac r c )+\frac{\omega d}{2c} cos \theta \right ]
Please help me on how to derive this. I know this is more a trig problem, but it has to be in the context of dipole radiation, this why I post it here instead.
Thanks
Alan
Science news on Phys.org
I tried and this is the only one I come up with and it is quite lame:
Assuming the vector from the center of the dipole to the field point is \vec{\eta} and vector from the +ve charge to field point is \vec{\eta}_+. Using Law of Cosine:
(\eta_+)^2=\eta^2 + (\frac d 2)^2 - 2\frac d 2 \eta cos \theta \;\Rightarrow\; cos\theta = \frac { \eta^2 +(\frac d 2)^2-(\eta_+)^2}{ d\eta} \cong \frac {\eta^2 -(\eta_+)^2}{ d\eta}
cos \left [\omega(t-\frac {\eta} c)+\frac{\omega d}{2c}cos\theta \right]= cos\left [\omega(t-\frac {\eta} c)+\frac{\omega d}{2c}\frac {\eta^2 -(\eta_+)^2}{ d\eta}\right ]= cos \left [ \omega \left ( t-\frac {\eta} c + \frac d {2c} \frac {\eta^2 -(\eta_+)^2}{ d\eta}\right ) \right ] = cos \left [ \omega \left ( t- \frac {2\eta^2 - \eta^2 + (\eta_+)^2}{2c\eta}\right ) \right ]
For d<<\eta \;\Rightarrow \; \eta_+\cong \eta.
cos \left [\omega(t-\frac {\eta} c)+\frac{\omega d}{2c}cos\theta \right] = cos \left [ \omega \left ( t- \frac { \eta^2 + (\eta_+)^2}{2c\eta}\right ) \right ] \cong cos \left [ \omega \left ( t- \frac { \eta + \eta_+}{2c}\right ) \right ] \cong cos \left [ \omega \left ( t- \frac { \eta_+}{c}\right ) \right ]
But this is very lame and stretching it!
Piece of cake.
η+ = √(r2 + d2 -2dr cos θ) [Law of cosines]
≈ r - d cos θ [Binomial theorem]
so cos [ω(t - η+/c)] ≈ cos[ωt - ωr/c + ωd/c cos θ]
(missing factor of 2 is apparently because I defined d as the distance of each charge from the origin, whereas you defined it as the distance between them.)
Bill_K said:
Piece of cake.
Thanks for your reply, can you explain a little more on Binomial theorem?
Alan
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
