Help me analyze the situation of torque
  • Thread starter Thread starter tukms
    Torque
The discussion centers on the confusion regarding the textbook conclusion that the net internal torque equals zero, akin to Newton's third law. The user questions how torque, defined as r × F, can lead to this conclusion when considering internal forces F21 and F12. A key point raised is that the internal forces are assumed to act along the line of separation between particles, leading to a total moment that results in zero torque. The clarification emphasizes that since the vector difference r1 - r2 is parallel to the force F12, the total moment cancels out. This analysis helps resolve the user's uncertainty about the textbook's assertion.
tukms
I have a confusion of a conclusion in the textbook ( I posted it in the attach file )
Net internal torque equals zero ( similarly to conclusion in the Newton’s third law ) but I myself reckon that torque is defined as
$rm{r \times F$
And maybe there occurs the case below :
$rm{F}}_{{\rm{21}}} {\rm{ = - F}}_{{\rm{12} $
But
$rm{r}}_{21} {\rm{F}}_{{\rm{21}}} \ne {\rm{r}}_{12} {\rm{ - F}}_{{\rm{12}$
Could someone help me analyze this situation , I think that the conclusion in textbook is true but it is still fuzzy for me
Thank you in advance
I only try to post Latex but no success :(
again
${\rm{r \times F}}$
${\rm{F}}_{{\rm{21}}} {\rm{ = - F}}_{{\rm{12}}} $
But
${\rm{r}}_{21} {\rm{F}}_{{\rm{21}}} \ne {\rm{r}}_{12} {\rm{ - F}}_{{\rm{12}}} $
though I can't post Latex truly , i guess you would know my confusion , please answer me as soon as possible
thank you :)
You must use [tex*] and [*/tex] (with out the *) on your latex code.
welcome to pf!
hi tukms! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
the important point in your attachment is "we assume that these forces lie along the line of separation of each pair of particles" …
so if the internal forces are F12 and F21, at positions r1 and r2,
then the total moment (about any origin) is r1 x F12 + r2 x F21 = (r1 - r2) x F12
since r1 - r2 is parallel to F12, that comes to zero :wink:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
