Help me somebody explain this to me(Gauss's Law)
  • Thread starter Thread starter nutzweb
    Explain Law
The discussion centers on Gauss's Law and its implications for electric fields in conductors. It highlights that the electric field inside a hollow conductor is zero, regardless of the charge on its surface, which suggests that a person inside a car during a thunderstorm is safe due to this shielding effect. Additionally, it confirms that the electric field inside an empty cavity within a conductor is also zero, as there is no net charge present, aligning with the principles of electrostatic shielding. The conversation emphasizes the importance of understanding these concepts for practical safety applications. Overall, the principles of Gauss's Law demonstrate how conductors protect against external electric fields.
nutzweb
i have a couple of questions and evryone can answer and explain it to me..
1. what are the practical consequences of the observation that the electric field inside a hollow conductor is zero regardless of how much electric charge is placed on its outer surface? what does this imply regarding the safety of a person inside an automobile in a thunderstorm?
2. is the electric field inside an empty cavity in a conductor zero? Why or why not?
1) Shielding.. look into this.
2) Yes, of course. Since there is no net charge inside the cavity, Gauss' law says there cannot be an electric field.
1) This phenomenon is known as " Electrostatic Shielding' as per which the charge(s) inside a conductor are shielded from outside electric influences.The consequences include:
i)Electric Field Vector on the surface of the conductor is always prependicular to the surface
ii) The net field inside a conductor is zero.
iii) Because the charges on a conductor rest on the surface, there are no charges in the cavity inside the conductor and hence no electric field as per Gauss Law.
BJ
Please do not multiple post!
Zz.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
