I Help me understand heating/cooling principles
  • I
  • Thread starter Thread starter lavalin
    Cooling Heating
The discussion revolves around temperature variations in a closet with two shelves and fans installed above the doors. When fans blow ambient air into the closet, the lower shelves become hotter than the upper shelves, while reversing the fan direction results in the opposite temperature gradient. This phenomenon is attributed to the principles of convection, where warm air rises and cooler air sinks, causing uneven temperature distribution. The introduction of cooler ambient air mixes with the warmer air inside, gradually cooling it down over time. Understanding these principles can help optimize airflow and temperature regulation in the closet.
lavalin
Hello
I have a closet with two double doors. There’s a 3mm gap between the doors and a 10mm gap down the bottom. I have a few fans mounted above the doors in the wall.
Ambient air is always 2-3deg cooler than inside the closet due to some electrical equipment I have running in there.
I have 2 shelves in the closet. On each shelf there’s a temperature sensor which are closely calibrated. Between the shelves and the doors is a 150mm gap.
When I orientate the fans to blow ambient air in, the lower shelves are about 2 degrees hotter than the upper shelves. When I orientate the fans to extra air out of the closet, the top shelf is about 2 degrees hotter than the bottom shelves.
Just curious to understand the science behind why this is happening.
Also if I pull air into the cabinet which is 2deg cooler than inside the cabinet, what happens to the warm air inside the cabinet? Does it simply mix and just cool down over time? Or is there another explanation
... inside the closet due to some electrical equipment I have running in there.
When the fans blow air in at the top, the outflow of the heated up air is at the bottom.
When the fans blow air out at the top, the outflow of the heated up air is at the top.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
