MHB Help Needed: Calculating Speed After Motorcycle Accident
Andre seeks assistance in calculating the speed of his motorcycle at the time of a collision, providing details about the accident's dynamics, including distances and angles. Dan analyzes the situation, estimating the horizontal component of the velocity at impact to be approximately 6.859 m/s, based on assumptions about sliding friction. He notes inconsistencies in the data, particularly regarding the vertical motion and launch angle, which complicate the calculations. Additional information about the friction coefficients for different materials is provided, suggesting that the actual speed at impact is likely higher than the calculated estimate. Accurate calculations require more consistent data on the motorcycle's position and the impact dynamics.
bikerguy
Hi there Ladies and Gentlemen. My name is Andre, and I am from South Africa and would like if someone could assist me.
Im going to admit that maths is not my forte and I am lost when it comes to anything more than plus or minus or times. lol
I was in a motorcycle accident recently , and after spending months in hospital, I now face the Court cases. I would like someone to help in finding one thing: What speed was I traveling upon collision?
Point of impact to where I came to contact with tarmac, is 12m
Hight of launch point is 1.2m above contact point
I weigh 109 kilograms
i rolled another 3m
Launch angle is between 10 to 20 degrees, although, this is the general estimate found on the internet.
if anyone can help, it would be appreciated, as i cannot afford an attorney, and I will have to make my own representation in court.
Thank You!
Mathematics news on Phys.org
It would greatly help the analysis if you could please post a picture or drawing of the physical situation, with labels for everything you know.
HI Ackbach, here is what i know
I've done a couple of checks on this and the only thing I can think of is that your numbers are inconsistent.
The sliding part is pretty decent. I couldn't get any sort of "rolling friction" data so I had to assume that the rider is sliding. This would imply a speed greater than that predicted by rolling, but I can't say by how much. Anyway the estimate of the horizontal component of the velocity at impact will be [math]\sqrt{6 \mu _s g} \approx 6.859~\text{ m/s}[/math] using a hybrid guess of [math]\mu _s = 0.8[/math]. The guess comes from an eyeball judgement of 4 different surface combinations that I thought were relevant.
So far so good. Now for the projectile part of the motion. To do this properly the initial vertical motion is caused by a rotation of the motorcycle at the point of impact with the truck. I need the horizontal distance from the back of the truck to where the rider is sitting and the vertical distance from the back of the truck to how high the rider was sitting. Without this information we have to confine ourselves to a consistency check on the speed found from the sliding part of the motion.
Again we are missing data. The simplest way to continue here is to assume that h is about 1.5 m. But that is where this all goes to Hades. I'm taking the horizontal component of the velocity at the point of impact to be our previously calculated 6.859 m/s and we need to find an initial vertical component of velocity. This comes in at more than 19.795 m/s, which implies an angle some 70 degrees. But this angle has to be less than the 15 degrees you are estimating.
The only conclusion I can draw is that the speed the motorcycle hits the truck with is significantly greater than the predicted 6.859 m/s (15.3 mph). Without more consistent data that's all I can say.
-Dan
-Dan
Thank You Dan,
Perhaps this can help?
Studies show that the coefficient of friction between the operator’s clothing and the roadway surface for cotton/ wool and polyester is between .7 to .85 g’s and for leather is between .6 to .7 g’s. When a body does not slide but tumbles the coefficient of friction is approximately 1.0 or higher. There may be a combination of sliding and tumbling so the slide to stop coefficient of friction may vary
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
