Help needed with velocity and acceleration question
In summary, the equation of the motion of a particle is given by s=${t}^{2}$-3t, where s is in meters and t is in seconds. To find the velocity and acceleration as functions of t, we take the first and second derivatives, respectively. The logic behind this is that velocity measures the time rate of change of position, while acceleration measures the time rate of change of velocity. The units of velocity are meters per second, and the units of acceleration are meters per second per second. The book's answers are correct, as shown by the calculation for acceleration after 2 seconds being 12$\frac{m}{{s}^{2}}$.
lastochka
29
Hello,
I need help with this question. I do have the answers, but I am not sure what is the logic behind these answers.
Here is the exercise
The equation of the motion of the particle is s=${t}^{2}$-3t, where s is in meters and t is in seconds. Find:a) the velocity and acceleration as function of t.
Logically I guess they asked about derivative, so here is what I did on my own, I took first derivative
f$^{\prime}$(x)=3${t}^{2}$-3 which is velocity? so according to my book second derivative is acceleration
a(t)+v$^{\prime}$(t)=6t
The answers are correct (from the book), but I don't understand why first derivative is velocity and second derivative is acceleration?? What is the logic behind it?
b)acceleration after 2 seconds
a(2)=6(2)=12$\frac{m}{{s}^{2}}$
Why are the seconds squared?I am very confused...help please.
Thank you
I am assuming you meant to given the position function as:
\(\displaystyle s(t)=t^3-3t\)
Now, using the definition that velocity $v$ is the time rate of change of position, we find:
\(\displaystyle v(t)=\d{s}{t}=3t^2-3\)
And similarly using the definition that acceleration $a$ is the time rate of change of velocity, we find:
\(\displaystyle a=\d{v}{t}=6t\)
These are just the way that velocity and acceleration are defined: velocity measures how fast position is changing and acceleration measures how fast velocity is changing.
If position is given in meters, and time measured in seconds, then velocity will be in meters per second $\dfrac{\text{m}}{{s}}$ and acceleration will be in meters per second per second $\dfrac{\frac{\text{m}}{\text{s}}}{\text{s}}=\dfrac{\text{m}}{\text{s}^2}$.
Thank you! It is so clear now :)
FAQ: Help needed with velocity and acceleration question
What is the difference between velocity and acceleration?
Velocity is a measure of an object's speed and direction of motion. It is a vector quantity, meaning it has both magnitude and direction. Acceleration, on the other hand, is the rate at which an object's velocity changes over time. It is also a vector quantity and is expressed in units of distance per time squared.
How do you calculate average velocity?
The formula for average velocity is displacement divided by the time interval. Displacement is the change in position of an object, and time interval is the amount of time it takes to make that change. Average velocity is expressed in units of distance per time, such as meters per second or miles per hour.
What is the difference between average velocity and instantaneous velocity?
Average velocity is a measure of an object's overall motion over a specific time interval. It is calculated by dividing the total displacement by the total time. Instantaneous velocity, on the other hand, is the velocity of an object at a specific moment in time. It is calculated by taking the derivative of the position function with respect to time.
How does acceleration affect an object's motion?
Acceleration affects an object's motion by changing its velocity. If an object is accelerating, its velocity will either increase or decrease depending on the direction of acceleration. If the acceleration is in the same direction as the object's velocity, it will increase the object's speed. If the acceleration is in the opposite direction, it will decrease the object's speed.
What is the difference between positive and negative acceleration?
Positive acceleration occurs when an object's velocity is increasing over time, while negative acceleration (also known as deceleration) occurs when an object's velocity is decreasing over time. Both types of acceleration are considered to be changes in velocity, just in opposite directions. Positive acceleration is often associated with speeding up, while negative acceleration is associated with slowing down.
