Help on simulating a circuit - First attempt didn't work
  • Engineering
  • Thread starter sampsoninc916
  • Tags
    Circuit Work
In summary, the conversation was about a student's project to simulate a circuit and their struggles with using a simulation software. They had already selected a project and gathered the necessary parts, but needed help with simulating the circuit. The first attempt was not successful and they were seeking assistance for their second attempt. The conversation also discussed different simulation software options and the availability of certain models within those programs.
sampsoninc916
The assignment for me is to simulate a circuit. I've already selected a project and I have already gathered parts thanks to my parents, but I need help on simulating the circuit. My first attempt did not go so well. The final steps of the project is to build the project on a breadboard, which I can do with my dad, and build it on a perf board, which I can do with my dad as well.
Here's the app I am using to simulate the circuit:
http://www.falstad.com/circuit/
Here's the circuit I'm supposed to simulate:
Information about the circuit
The Circuit
I just need to build the circuit, there really is no relevant equations as this is a project for assembling a circuit, not some help on homework or studying for a test.
Here's my first attempt at doing the circuit:
http://l.bitcasa.com/C4FVbXxJ
It did not work out so well because it did not become animated, like it was supposed to have simulated electricity flowing through it.
May you please help me on my second attempt to simulate the circuit. I believe the root of my problem is not understanding where what specific wires were supposed to go inside the IC1 555 Timer. I need to simulate the circuit by the end of this weekend.
The Circuit
Why did you re-draw the circuit in such a strange arrangement? In addition to being very hard to read, it looks like you have mis-connected several things, including the power supply connection for the IC.
I'd recommend that you draw the circuit in the simulation software exactly as it is shown in the example schematic.
The simulation software only had an IC 555 timer that had 7 outputs, and they weren't even numbered, whereas the example schematic had 8 outputs and were numbers. Can you recommend me a circuit simulation software that can do just that? Why 7 and not 8? Why the strange th, tr, ctl, labels? Why couldn't they be numbered to make it easier for me?
You could try the free version of LTSPICE:
http://www.linear.com/designtools/software/?gclid=CK3A6-eS7b0CFUFrfgodrDcApg#LTspice
:smile:
I can't find an IC1 NE555 Timer in LTSPICE. May you please help me find it?
Hmm, that's unfortunate. Try doing a Google search for NE555 spice model...
sampsoninc916 said:
I am working with a spice model for NE555, but it looks like this:
http://en.wikipedia.org/wiki/File:555_Pinout.svg
Instead of this:
http://www.circuitstoday.com/wp-content/uploads/2011/04/water-level-controller-circuit.png
I can't find a NE555 spice model timer with that specific arrangement of the numbers 1-8. May you please help me?
Those two pinouts look the same to me. Check out the datasheet for the NE555, and it will probably show the circuit connections that you have in your example circuit.
Where are the relays in LTSPICE? Here's what I currently have with building the circuit schematic:
http://l.bitcasa.com/s7LnX-v3 May you please help me?
There are many circuit simulators online. Falstad's seems too "experimental" to what you need.
LTSpice, as suggested should do just fine.
You could teach yourself a bit about it first. Check out some YouTube tutorials for it.
Maybe this link can help you:
http://forum.allaboutcircuits.com/showpost.php?p=526887&postcount=2
You may need to download some models to build what you want. LTSpice is not so fully-featured from start.
I did the circuit in LTSPICE, but here's the schematic of my circuit, which the professor said looks good:
http://l.bitcasa.com/X-bpPMWt
But here is the error dialog that pops up whenever I try to run the simulation:
Circuit: * C:\Users\user\Documents\waterlevelcontrollercircuit.asc
Error on line 4 : q4 n007 n021 n016 0 bc546
Unable to find definition of model "bc546"
Error on line 7 : q5 n017 n018 n019 0 pn2222
Unable to find definition of model "pn2222"
Error on line 8 : q6 n019 n022 n020 0 pn2222
Error on line 13 : d4 n020 n007 1n4007
Unable to find definition of model "1n4007"
Error on line 20 : d3 n005 n011 led
Unable to find definition of model "led"
Error on line 21 : q3 n011 n015 n007 0 bc546
Error on line 24 : d2 n004 n006 led
Error on line 25 : q2 n006 n012 n007 0 bc546
Error on line 28 : d1 n003 n009 led
Error on line 29 : q1 n009 n014 n007 0 bc546
WARNING: Node U1:N003 is floating.
WARNING: Node NC_03 is floating.
WARNING: Less than two connections to node NC_01. This node is used by V1.
WARNING: Less than two connections to node NC_06. This node is used by R3.
WARNING: Less than two connections to node NC_07. This node is used by R2.
WARNING: Less than two connections to node NC_08. This node is used by R1.
Direct Newton iteration for .op point succeeded.
Singular matrix: Check node nc_02
Iteration No. 2
Fatal Error: Singular matrix: check node nc_02
Iteration No. 2
This circuit has floating nodes.May you please help me with this?
You have many wires simply hanging by. What did you try to do? What should those dead-ends be doing?
Related to Help on simulating a circuit - First attempt didn't work
1. What could be causing my circuit simulation to not work?
There could be several reasons why your circuit simulation is not working. It could be due to incorrect circuit design, faulty components, or incorrect input values. Double check your circuit schematic and make sure all components are connected correctly.
2. My circuit simulation is giving unexpected results, how can I troubleshoot this?
If your circuit simulation is giving unexpected results, first check your circuit design and make sure it matches your intended circuit. Also, check your input values and make sure they are within the appropriate range. You may also want to simulate the circuit using different software or tools to see if the issue persists.
3. How can I improve the accuracy of my circuit simulation?
To improve the accuracy of your circuit simulation, you can use more precise components and input values. You can also try using different simulation methods, such as transient or frequency domain analysis, to get a more accurate representation of your circuit's behavior.
4. I am new to circuit simulation, where can I find resources to help me learn?
There are many online resources available to help beginners learn about circuit simulation. You can find tutorials, videos, and forums where you can ask for help and advice from experienced users. You can also refer to the documentation of the simulation software you are using for more specific guidance.
5. Can I use circuit simulation to design real-life circuits?
Yes, circuit simulation is a valuable tool for designing and testing real-life circuits before physically building them. It allows you to quickly and easily make changes to your circuit design and see how they affect the overall performance. However, it is always recommended to physically test the circuit after simulation to ensure its functionality.
