Help required in some amplifiere problem
  • Thread starter Thread starter shaiqbashir
The discussion focuses on calculating key parameters for a Class A amplifier, including minimum transistor power rating, AC output power, efficiency, and maximum load power. The original formulas proposed by the user are critiqued, particularly the misunderstanding of quiescent power versus actual power dissipated in the circuit. It is emphasized that the collector voltage cannot simply be assumed to be half of Vcc due to significant voltage drop across the collector resistor. Additionally, the power in the load is only relevant when an AC signal is present, contradicting the user's approach to using quiescent values for calculations. Clarification and corrections are sought to ensure accurate analysis of the amplifier's performance.
shaiqbashir
OKz here is the question to be considered:
Determine the following values for the class A amplifier when operated with maximum possible output signal:
1)Min transistor power rating
2) AC output power
3) Efficiency
4) Maximum Load Power
okz so here is what i think about these formulae:
1) this is the power at Quiscent point. that is
P = Icq x Vceq
where Icq is simply the Ic of the circuit and Vceq is the Vcc/2
2) that would be P = 0.5 Icq x Vceq
3) Efficiency = 0.5 Icq x Vceq/ Vcc x Icq
4) for max load power, it think i should use this formula :
P = (Vc^2)/RL
where i can find Vc = Vcc - Ic Rc
where RL is the capacitively coupled Load Resistor.
Please tell me that have i written the above formulae correctly or not. If not then what are the correct formulae.
I shall be thankful to u for this act of kindness.
take carez!
Good Bye!
Hi again. As I said in your other thread about class A amps, we need more info and hopefully a schematic. Can you post something?
Hi audioguru!
we do have a schematic, due to some problems, i cannot attach a schematic, but help u visualize that.
It is a simple common emitter configuration class A amplifier.
With R1 = 5.7 k , R2= 1K
R1 and R2 forms a voltage divider bias.
Vcc = 24V
Rc= 330 ohms
RE = 100 ohms
RL= 330 ohms
beta = 150
there is a capacitor bypassing RE to ground. the value is not given
there is a capacitor coupling RL to the collector, the value is not given.
I hope this is much info, please visualize this circuit. and remember it is for the second question.
I shall be looking forward for ur precious help.
Take carez!
Good Bye!
SB--
The quiescent power consumed by the whole circuit is the power supply voltage multiplied by the current drawn from the power supply. What you have written in your first post is the power dissipated by the transistor. The collector and emitter resistor will dissipate significant power also.
I also find that the collector voltage will be about 9.5 volts. So over half the power supply voltage is already lost across the collector resistor. So the voltage between the collector and emitter CANNOT be one half of Vcc.
The power in the load is ONLY AC. You cannot use the quiescent voltage on the collector to determine this. When there is no AC (signal) on the collector, no power is dissipated in the load.
There may be other mistakes, I skimmed it kinda fast and don't have the time right now.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
9K
11K
