Help Understanding Bushing Lubrication in Automotive Industry
Polyurethane bushings in the automotive industry require periodic greasing to prevent squeaking, while rubber bushings are typically designed to run dry and do not need lubrication. Rubber bushings are chemically bonded to metal components, which minimizes movement and noise, making them less prone to squeaking. Although some older vehicles still have original rubber bushings that have never been greased, there is debate about the potential benefits of using silicone grease, which is safer for rubber than petroleum-based products. Proper application of grease is crucial, and following manufacturer recommendations is advised, as some poly bushings may not need servicing after initial installation if greased correctly. Ultimately, understanding the lubrication needs of different bushing materials is essential for optimal vehicle performance.
YoshiMoshi
Hello Friends,
So I have seen that polyurethane bushings in the automotive industry are greased every few years or otherwise squeaking will occur. This got me thinking if Rubber bushings in the automotive industry ever need to be greased? I think they are designed to run "dry" and don't need lubrication? I have heard of vehicles that are two to three decades old that have original rubber bushings that have never been greased. But is there any benefit in greasing them?
I've read that silicone can be very beneficial to rubber. Silicone grease can come in either a spray can or grease cartridge form. I've read that petroleum in spray cans is bad for the rubber and can deteriorate it. So silicone grease in a cartridge should be used. Should you inject the grease into the rubber with a needle so it gets absorbed into the bushing, or just put it on the top of the bushing were it is exposed to the elements?
No, because:
https://www.suspension.com/blog/rubber-v-polyurethane-suspension-bushings/ said:
Rubber does not squeak since the bushing is chemically bonded to the metal shell and sleeve. The torque of suspension movement is soaked up by the bushing internally so the rubber does not move against the metal, and thus, no noise
You should follow what is recommended by the manufacturer. It is usually a matter of properly greasing them once, during the installation:
Poly bushing design has advanced over the years and even now some manufacturers will guarantee that if their bushings are properly greased upon install later servicing will not be required. Using the right kind of grease for poly bushings is imperative since some grease does not have the same staying power as other options.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 19 ·
10K
