Help with 2 gen chem questions please
  • Thread starter Thread starter amar314
    Chem
The discussion revolves around two chemistry questions related to isotopes and weight percent calculations. For the first question regarding the mythical element Z, the average atomic mass and the percentage of one isotope are provided, leading to the conclusion that the other isotope's mass can be calculated using the average mass formula. The second question involves precipitating fluorine from a soluble metal fluoride using calcium nitrate, requiring the calculation of weight percent based on equivalents and moles. The responses highlight the importance of understanding average atomic mass and equivalent weight in solving these problems. Overall, the thread offers guidance on approaching these chemistry concepts effectively.
amar314
Hello everyone, first time poster here.
I'm hoping someone can help me with these two questions, they're part of a study guide for my upcoming chem 1 exam.
Mythical element Z has an avg atomic mass of 107.9 u and is known to have only two naturally occurring isotopes. If 48.16% of Z exists as 109Z (108.971 u) what's the other isotope and its atomic mass?
a) 107 Z ; 106.9 u
b) 108 Z ; 107.9 u
c) 110 Z ; 109.9 u
d) 111 Z ; 111.1 u
e) 110 Z ; 110.2 u
and this one:
Fluorine can be precipitated out of solution with the use of calcium to create CaF2 (s). The use of 85.75mL of 0.3510 M Ca(NO3)2 precipitated out all of the fluorine present in a 4.585g sample of a soluble metal fluoride dissolved in water. Calculate the weight percent of fluorine in the sample.
a) 24.95%
b) 11.44%
c) 56.48%
d) 10.10%
e) 12.58%
I attempted both a few times but with no success, I'm just not sure how to start for either, especially the wording in the second problem is very confusing for me.
Any help is super appreciated, thank you so much!
Hello Amar314,
The questions are actually simple. For the first one, the questions says that Z's average atomic mass is 107.9u and 48.16% of Z exists as 109Z (108.971 u); which means, 100-48.16 = 51.84% is made up of the other one.
So, going by the formula for Mean/Average, we get
Average Mass = (P')*[Mass of one] + (P'')*[Mass of the other]
2) For the second question,
Ca(NO3)2 + MFx (x=unknown) ------> CaF2
(Hint:No. of equivalents of Ca+2 = Number of equivalents of F- )
Try to find out the N factor.
Equivalents = Moles*Nfactor
NB: If you are not aware of equivalent weight and stuff, I suggest you to read :
http://www4.ncsu.edu/~franzen/public_html/CH201/lecture/Lecture_19.pdf
Hope this helps!
ADI.
Adithyan said:
Hello Amar314,
Hope this helps!
ADI.
Thank you so much! I really appreciate your help!
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
