Help with breakdown voltage x gap spacing graph
  • Engineering
  • Thread starter portace
  • Tags
    Dielectric
In summary, the document discusses the relationship between breakdown voltage and gap spacing in electrical systems. It explains how increasing the distance between electrodes typically leads to higher breakdown voltage due to the reduced electric field strength. The graph illustrates this relationship, highlighting key factors that influence breakdown voltage, such as atmospheric pressure and temperature. The content aims to provide a clearer understanding of how these variables interact and affect electrical insulation and discharge phenomena.
portace
idk
idk
Hello! I'm studying a Dielectrics subject in my master's degree which is a little distant from my Electronics area. The teacher asked for a report on the following graph.In this case, the class was about rupture in gaseous dielectrics. The teacher is a little scattered and presents the class in a confusing way. But the caption before the graph is:
"From a practical engineering point of view, rod-to-rod gap and ball-to-ball gap are of great importance, as they are used for the measurement of high voltages and for the protection of electrical equipment such as transformers. The rupture characteristics of rod-rod gaps are shown below."
NOTE: Translated from Portuguese.
The professor asked to explain what happens and why there are different values of breakdown voltage when the impulses shown in the graph are added. However, I'm having difficulty interpreting this data and I'm not finding good references for my work (I'm not using the correct words in the search, I think).
Can you help me with references or textbooks? Thank you very much in advance
A key term here is Paschen Curves -- Have a look at this Wikipedia article and some of its references for more background.
https://en.wikipedia.org/wiki/Paschen's_law
Also, on the different breakdown voltages for short pulses, look into the propagation time for the ionizing particles between the gaps... :smile:
Likes DaveE
FAQ: Help with breakdown voltage x gap spacing graph
What is breakdown voltage in the context of gap spacing?
Breakdown voltage is the minimum voltage that causes a portion of an insulator to become electrically conductive. In the context of gap spacing, it refers to the voltage at which an electrical discharge occurs across a specified distance between two conductive materials.
How does gap spacing affect breakdown voltage?
Gap spacing directly affects breakdown voltage; generally, the larger the gap, the higher the breakdown voltage required. This relationship is often non-linear and can be influenced by factors such as the type of gas or material between the conductors, pressure, and temperature.
What is Paschen's Law and how does it relate to breakdown voltage and gap spacing?
Paschen's Law describes the relationship between the breakdown voltage and the product of pressure and gap distance for a given gas. It shows that breakdown voltage varies with the product of pressure and gap spacing and can predict the voltage at which electrical breakdown will occur in a gas-filled gap.
Can breakdown voltage be influenced by environmental conditions?
Yes, environmental conditions such as temperature, humidity, and pressure can significantly influence breakdown voltage. For instance, higher humidity can lower breakdown voltage, while higher pressure generally increases it.
What are some common applications of understanding breakdown voltage and gap spacing?
Understanding breakdown voltage and gap spacing is crucial in designing electrical and electronic systems, such as insulators, circuit breakers, and spark gaps. It ensures safety and reliability in high-voltage equipment, preventing unintentional electrical discharges.
