Help with conservation of energy
In an elastic collision involving two billiard balls of equal mass, the conservation of momentum and energy principles apply. The initial velocities are given as Ball A moving at 2.0 m/s along the y-axis and Ball B at 3.7 m/s along the x-axis. After the collision, Ball B moves along the positive y-axis, leaving the direction and speed of Ball A as unknowns. To solve for these, one must set up equations for momentum in both the x and y directions, while also considering kinetic energy conservation. The discussion emphasizes that finding the velocities of Ball A in both directions will ultimately reveal its final direction.
engineer2010
Two billiard balls move of equal mass move at right angles and meet at the origin of an xy coorindate system. Ball A is moving upward along the y-axis at 2.0m/s and ball B is moving to the right along the x-axis with a speed of 3.7m/s. After the collision, assumed elastic, ball B is moving along the positive y-axis . What is the final direction of Ball A and what is their speeds.
Conservation of momentum :
MaVax+MbVbx=MaV'ax+MbV'bx
I know that the masses cancel as they are the same.
But that still leaves me with 2 unknowns in that equation. Do I have to use trig functions to fing the velociy of ball B and then use the momentum to find velocity of ball A?? but then how do i find the direction of ball A
In an elastic collision linear momentum and energy are conserved. You have two independent lines (x and y) so that gives you three equations ...
O right sorry I forgot to write out the equation for the momentum along y. so in the x equation for example Vax= 0 and simiarly for the y equation? and is the third equation the kinetic energy one?? But I am sill confused as too how i find the direction of the A Ball.
Don't worry about finding the direction of the A ball; if you find its velocity in the x direction and its velocity in the y direction ...
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
