Help with Constant Acceleration Lab
The discussion centers around a lab experiment aimed at determining the initial velocity (Vo) and maximum height (dy) of a ball thrown into the air. The procedure involves throwing a tennis ball and timing its flight over three trials, with average times recorded for both throwing and hitting the ball. The main challenge is calculating Vo, as the initial velocity is not zero when the ball leaves the hand. The teacher suggests using equations of motion for constant acceleration, but the student struggles with which equation to apply and how to find dy since height is not explicitly included in the equations. Guidance is provided on understanding the relationship between the time of ascent and total flight time, as well as the behavior of the ball at its peak height, encouraging the student to derive the necessary calculations independently for a deeper understanding.
daodude1987
[SOLVED] Help with Constant Acceleration Lab
Hey guys, thanks for reading my post. I'm really confused about a lab that was assigned by my teacher. I will try to explain the whole lab the best I can.
Lab: The Balls Lab
Purpose of the Lab: To determine the initial velocity (Vo) and maximum height (dy) of a thrown (and hit) ball
Procedure/Materials:
Materials: tennis ball, tennis racket, stop watch
1. Throw a ball straight up into the air
2. Measure the time the ball is in the air and comes down
3. Due three trials
Data: (here are the 3 time results I got for the ball)
Throwing
Trial 1- 3.21 seconds
Trial 2- 3.10 seconds
Trial 3- 2.94 seconds
Average- 3.08 seconds
Hitting the ball with tennis racket
Trial 1- 1.41 seconds
Trial 2- 2.88 seconds
Trial 3- 1.87 seconds
Average- 2.05 seconds
Conclusion:
Ok here is the problem... I have no clue how to start solving for the initial velocity (Vo) for the average of the ball thrown and hit in the air. At first I thought the initial velocity of the thrown ball was 0 because that is usually the velocity of any object at rest and then going into the air. But my teacher said it wasn't because he wanted the intial velocity from when it left my hand not when it is at rest, which is 0. He also told me that I needed to use one of the equations of motion for constant acceleration such as: Vf=Vo+at, d=1\2(Vf+Vo)t, d=Vo=1/2at(squared), or 2ad=(Vf)squared-(Vo)squared and the acceleration of gravity, -10 m/s to solve for Vo. But he wasn't clear on which one. Also it seems to me that each of these equation require the value of Vo itself! I am also very confused at how to find the height of the thrown ball (dy) because y is not given as a variable in any of these equations.
If you guys can show me how I can solve for the initial velocity (Vo) and the maximum height(dy) of the of the ball thrown using any of the equations above or even your own methods, please enlighten me with you explanation. I am most grateful.
Thank you for taking the time to answer.
Hi,
Initial velocity:
You must think what is the relation between the time that the ball goes up and the total time of the movement you have measured. Then you must think what happens to the velocity of the ball when it reaches the highest spot of its orbit. With the above data and the proper equation of motion you can calculate the initial velocity.
Height of the throw:
You have calculated the initial velocity so the only thing you need is the time that the ball needed to get from your hand to its highest spot.
Sorry, I don’t give you the exact equations and values of time and velocity but if you fallow the steps I have written above I am sure that you will solve the problem by your own. You must think if you want to gain knowledge and on the other hand you will feel so great when you find the solution.
Excuse me for the sermon.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
