Help with easy problems that I just can't seem to get right
  • Thread starter Thread starter supermenscher
The discussion revolves around a user struggling with basic physics problems related to wavelength and frequency calculations. They repeatedly provide incorrect answers for radar signals, electromagnetic waves, and light wavelengths, expressing frustration over their mistakes. Other forum members suggest that the user may be submitting answers without proper units and emphasize the importance of understanding concepts rather than just seeking answers. Additionally, there are concerns raised about the user's pattern of seeking help without demonstrating learning or engagement with the material. The conversation highlights the need for a deeper grasp of physics principles to solve these problems correctly.
supermenscher
I think I am doing these right, but I keep getting them wrong...can anyone show me what I am doing wrong.
1. What is the wavelength of a 29.00E9 Hz radar signal.
I did wavelength = c/f = 3.00E8m/s divided by 29.00 Hz and got 0.01034, but it is telling me that it is wrong.
2. An em wave has a wavelength of 850nm, what is the frequency.
I did f = c/wavelength = 3.00E8m/s divided by 850E-9 m and got 3.53E14, and it told me it was wrong.
3. Calculate the frequency of green light with a wavelength of 540nm and yellow light with a wavelength of 580nm. I did freq of green = c/wavelength = 3.00E8/540E-9 and got 5.56E14 which was wrong, and 3.00E8/580E-9 = 5.17E14 which was also wrong.
4. A start is 2.1 light years away. How far is it away in meters? I converted 2.1 years to seconds, and then divided 3.00E8/2.1 years in seconds and got 9.06m, which was also wrong.
I know these problems are easy but I am frustrated with them because I can't get them right, I would really appreciated it if someone could help me out.
supermenscher said:
... but it is telling me that it is wrong.
What is "it"? Are you submitting these answers online or something? Or does "it" refers to the answers in your book? Do you have these answers? Can you post these answers?
It is submitting the answers online
Make sure you are submitting your answer in the proper format.
I am, do you have any other help besides submitting in the correct format
I'm guessing your answers to 1-3 are wrong because you did not enter any units. Number 4 you get 9 metres? The star is 9 metres away? Seriously? Read up on the definition of a lightyear.
Supermenscher, you've started 16 threads in this forum. They all have exactly the same format. You copy a problem verbatim from your assignment and ask us to give an answer. On 4 occasions, you were given a detailed answer and the exact result. On those 4 occasions you said thanks. On the other 12, we tried to get you to solve it yourself. In not one of those 12 did you respond with saying you found the answer as a result of the help. It appears you are not interested in learning physics, only in getting us to do your homework for you. Read the very first thread at the top of this forum again.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
