Engineering Help with home work question, RL circuit
The discussion revolves around solving for the current i(t) in an RL circuit defined by the voltage function vf= 4(u(t)-u(t-1.8))v. The user has successfully evaluated the circuit for t<0 but struggles with the range 0<t<1.8, particularly in finding the forced response as t approaches infinity. They express confusion regarding the impact of a controlled current source on their calculations using Kirchhoff's voltage law. Another participant suggests a simpler method to calculate the current i1, referencing the independent voltage source in the circuit. The original poster plans to share a solution and a clearer circuit diagram to aid understanding.
Quboid
I have to find i(t), for the attached circuit. I already evaluated it for t<0. But i a having problems in the rage 0<t<1.8.
I am at the point where i have to find the forced response, so o let t tend to infinity
(t->infinity). And so the Inductor acts like a short circuit, the problem i have is find the current that passes where the inductor short circuits, I get confused by the controlled current sources.
I so far used kirchhoff voltage law to find three equations, but i am not sure i am correct, nor what to do with the dependent current source that finds itself in an equation.
Thanks for helping...
Quboid...
is there any simple way of calculating i1 in the circuit, that would make things a lot easier.
Ok, i am thinking i1=i-(4v/5ohms). Note i got the 4 volts( which is supplied by the independent voltage source) from the scalar function vf, when evaluated in the range 0<t<1.8.
I've never seen some of the circuit elements in your drawing. Who's reinventing electronics and why?
I think if you want any help, you're going to need to decode that stuff.
Sorry about that. I didn't use a circuit schematic program to draw the circuit. I actually labelled them. I was hoping that would be sufficient. I solved the question yesterday one hour before the class. I will post the solution and a proper diagram shortly.
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
12K
9K
