Help with question on motion: Avoiding a rear-end collision
In summary, the topic discusses strategies to avoid rear-end collisions while driving. Key recommendations include maintaining a safe following distance, being aware of traffic conditions, anticipating the actions of the vehicle ahead, and using brakes smoothly to signal stops. Additionally, drivers should minimize distractions and stay alert to changes in speed and road conditions to enhance safety and avoid accidents.
Physics_is_beautiful
The question : A car and a truck are both traveling with a constant speed of 20 m/s. The car is 10 m behind the truck. The truck driver suddenly applies his brakes, causing the truck to slow to a stop at the constant rate of 2 m/s2. Two seconds later, the driver of the car applies their brakes and just manages to avoid a rear-end collision. Determine the constant rate at which the car slowed.
basic S,U,T,A,V equations
How I tried to solve it :
--> if truck decelerates at 2 m/s^2, then it covers s = ut+0.5at^2 distance by the time it stops.
= (20)(10)+(0.5)(-2)(100)
= 100m
--> however, the car is 10m behind the truck, thus the car travels 110m ( for the sake of calculation, we assume that 'nearly collide' = occupying the same space, as without the length of the truck, it's not feasible to calculate the distance for 'nearly colliding'.)
--> Therefore, we now know that the car decelerates at some speed, in some time, covering 110-40m = 70m (as the car starts decelerating 2 seconds after) before coming to a stop.
--> next, using avg speed = (v+u)/2 = 20/2 = 10m/s,
we calculate the time taken by :
time = 70m/10 m/s = 7s
--> Thus, we now calculate for a by a = (v-u)/t
= -20/7
= -2.8 ms^-2
However, when checking the answer script, the answer was given as -3.33 ms^-2
acceleration.
I then tried solving using v^2 = u^-2as, only to get - 2.8 approx. as the acceleration.
I then attempted to solve it by adding in the length of an average truck ( approx = 8.5m), substitute into formula, to get
0 = 400-123a
leading to a = -3.3
However, Had this been the case, they would have given the length of truck in the question, so I doubted this would be the correct solution.
The car has 8 seconds to travel 70 meters, starting at 20 m/sec?
Yes, but the distance between the vehicles is from rear of truck to front of car, so length of either vehicle is irrelevant.
Agree up to here, sort of. This is the calculation of how far the car will move before coming to a stop, but the collision doesn't occur at that point if the plan is to stop there. The car must brake hard enough to be zero distance from the truck when the two match speeds.
This is assuming an answer to the question asked, and a wrong one at that.
How long does the car have to come to a stop once the brakes are applied?
Better question: How long does it have to match speed with the truck once the brakes are applied?
The answer is the shorter time of the two.
You are making an unjustified assumption about the possible ways a collision might occur.
Likes nasu
= -20/7
= -2.33 ms^-2
But 20/7 = 2.8 approx., not 2.33!
acceleration.
So your 2 methods agree (as they should!). I think -2.8m/s² (approx.) is correct and the officiaL answer (-3.33m/s²) is wrong. But no one else has suggested this, so maybe I'm missing something.
Edit. The reason why -2.8m/s² is wrong is that it assumes that the car just avoids collision with the stationary truck. But you need to make sure that the car doesn't hit the truck while the truck is still decelerating. @haruspex hinted at this in Post #4
Likes Chestermiller
Avoiding the vehicle in front involves more than merely coming to rest at the same point.
Yes - I'd already edited my post.
FAQ: Help with question on motion: Avoiding a rear-end collision
What factors contribute to the risk of a rear-end collision?
Several factors contribute to the risk of a rear-end collision, including the following: driver inattention or distraction, following too closely (tailgating), sudden stops by the vehicle in front, adverse weather conditions reducing visibility and traction, and mechanical failures such as brake issues.
How can I calculate the safe following distance to avoid a rear-end collision?
The safe following distance can be calculated using the "three-second rule." Choose a stationary object on the road ahead, and when the vehicle in front of you passes it, start counting seconds. If you pass the same object before you reach three seconds, you're following too closely. In adverse conditions, increase the following distance to four or more seconds.
What should I do if the car in front of me suddenly stops?
If the car in front of you suddenly stops, you should immediately apply your brakes firmly but not so hard that you lose control of your vehicle. If possible, steer to avoid the collision while maintaining control of your vehicle. Always be aware of your surroundings and have an escape route in mind.
How do road conditions affect stopping distance?
Road conditions significantly affect stopping distance. Wet, icy, or uneven roads reduce tire traction, increasing the distance required to stop. Always adjust your driving speed and following distance according to the current road conditions to ensure you have enough time to stop safely.
What technologies can help prevent rear-end collisions?
Several modern technologies can help prevent rear-end collisions, including forward-collision warning (FCW) systems, automatic emergency braking (AEB), adaptive cruise control, and rearview cameras. These systems use sensors and cameras to detect potential collisions and either warn the driver or automatically apply the brakes to reduce the risk of a collision.
