I Help with sourcing a specific type of integrating sphere
A user is seeking a specific integrating sphere designed for capturing diffuse reflectance measurements, featuring two ports positioned at equal and opposite angles to eliminate specular reflections. They have struggled to find commercially available options, encountering only general-purpose spheres with different port configurations. Another participant successfully located the desired integrating sphere through Labsphere and shared the link for others interested in this specific design. This highlights the importance of specialized equipment in optical measurements. The discussion emphasizes the need for precise specifications in sourcing scientific instruments.
aferrie
I am looking for a specific type of integrating sphere that can be used to capture diffuse reflectance measurements, and I would appreciate help with locating a commercially availably version of this sphere. The diagram below illustrates the type of sphere I am looking for [1]. Two ports are located at equal an opposite angles from the sample normal so that light that is specularly reflected from the sample can be eliminated by a light trap placed in the non-source port.
I have looked online in attempt to find a commercially available integrating sphere with this design; however, I have only come across general purpose integrating spheres (such as this Edmund Optics one) that have ports located directly across or 90 degrees from each other. Any help locating this specific type of integrating sphere would be much appreciated.Reference
1. https://www.sciencedirect.com/topics/physics-and-astronomy/spectral-reflectance
Science news on Phys.org
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
