Help with Steady State Heat Transfer Problem
The discussion centers on a steady-state heat transfer problem involving a heat flux source of 400 W/m² from a lamp. The user seeks to calculate the heat flux through an arbitrarily oriented surface with air in between. To find the temperature distribution (T), it is suggested to solve the heat equation with appropriate boundary conditions, such as wall temperatures. For a simple square surface, it is noted that if the heat source is inside, the heat added must equal the heat leaving the walls to maintain a constant temperature. The user requests a simple example to better visualize the solution process.
Diego Saenz
Hello everyone,
I have this setady state, heat transfer problem; I hope you can help me with it.
I have flux source of 400 W/m² (a lamp), and i want to calculate the heat flux passing through a surface arbitrarily placed and oriented in the space. There is air in between. How can i do this?
I thought that I could use ∫∫(-k∇T)*(n dS)
But i don't know what ∇T is...
Thanks.
That will give you the answer once you've found T. Finding T involves solving the heat equation with a local heat source. You'll need some more boundary conditions to do this, e.g. what are the temperatures of the walls?
If your geometry is simply you can solve for T analytically then differentiate to find your heat flux through a surface.
If not, you'll need some software.
Hi mikeph,
My surface is simple, is a square. Is it possible to use this information to solve for T? Can you explain how can I do this?
Thanks
If the heat source is inside the surface then it's just 400 W/m^2, this is from energy conservation using the steady state assumption.
If you have a constant temperature distribution then the heat being added inside the box (400) must equal the heat leaving through the walls, otherwise the temperature of the box would have to increase which would introduce a time variation.
Likes 1 person
I really appreciate your help mikeph.
But I have problems visualizing the solution, could you provide simple example?
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
