Help with understanding equation for force Between two current carrying coils
The discussion focuses on understanding the force equation for a linear motor based on the coil gun principle, specifically the equations Fx = I1*I2*dM/dX and Fy = I1*I2*dM/dY. The active coil induces a current in a nearby passive coil, leading to magnetic repulsion due to like polarities. The user seeks clarification on how the rate of change of mutual inductance (dM/dX) relates to the force experienced, connecting it to established physics principles like the Lorentz Force equation. The mutual inductance describes the magnetic coupling between the coils, and its rate of change is crucial for understanding the resulting thrust in the linear motor. Overall, the discussion emphasizes the relationship between current, mutual inductance, and the resulting force in coil interactions.
Arv
Hi
I am currently involved in building a linear motor which is based around the coil gun principle. I am having trouble understanding the equation for force used to desribe the coilgun's action.
namely:
Fx = I1*I2*dM/dX
Fy = I1*I2*dM/dX
Here we are considering two coils of wire, with an rapidly
changing current allowed to flow through one of the coils (The active coil)which in turn induces a current in the nearby 'passive' coil (via Lenz Law). So I1 is the active current and I2 is the passive current.
So bascially u end up with two magnetic poles with same polarity and there is a repulsion action. If the vertical movement is constrained, you are left with horizontal thrust which is what the linear motor makes use of.
I can relate this force equation to physics textbooks' description of force betweentwo parallel current carrying conductors which uses the Lorentz Force equation (F = I*L*B) and Magnetic Field near straight wire (B = mu*I/(2*PI*R) to arrive at F = (mu*I1*I2)/(2*PI*D).
I don't how to explain the dM/dX part.
Can someone help me get from the F = I*L*B description to the
F = I*dM/dX description. Thanks
Arvind.
oh..the M in dM/dX is the mutual inductance..(a coefficient to describe the linking flux between the two coils..coupling). I can see how 'good coupling' can help induce large currents however, i don't understand how its rate of change contributes to force..
*Fy = I1*I2*dM/dY
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
