MHB Henry's question at Yahoo Answers concerning a surface of revolution
The discussion focuses on calculating the surface area generated by rotating the parametric curve defined by x = 3t² and y = 2t³ around the y-axis for t in the interval [0, 5]. The formula used for the surface area is S = 2π∫ x(t)√((dx/dt)² + (dy/dt)²) dt, leading to the integral S = 36π∫ t³√(1+t²) dt. Various substitutions are applied to simplify the integral, including trigonometric and geometric substitutions, ultimately yielding a complex expression for S. The final result is expressed in terms of π and involves square root terms. The discussion emphasizes the importance of careful substitution to streamline the computation process.
MarkFL
MHB
Here is the question:
Calculus 2 help me please?
Find the surface area generated by rotating the given curve about the y-axis.
x = 3t^2, y = 2t^3, 0 ≤ t ≤ 5
Here is a link to the question:
Calculus 2 help me please? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Henry,
We are asked to find the surface of rotation of the curve described parametrically by:
$x(t)=3t^2$
$y(t)=2t^3$
with $t$ in $[0,5]$.
Since the axis of rotation is the $y$-axis and $x(t)$ is non-negative on the given interval for $t$, we may use:
$\displaystyle S=2\pi\int_0^5 x(t)\sqrt{\left(\frac{dx}{dt} \right)^2+\left(\frac{dy}{dt} \right)^2}\,dt$
So, we compute:
$\displaystyle \frac{dx}{dt}=6t$
$\displaystyle \frac{dy}{dt}=6t^2$
and we have:
$\displaystyle S=2\pi\int_0^5 3t^2\sqrt{\left(6t \right)^2+\left(6t^2 \right)^2}\,dt$
$\displaystyle S=36\pi\int_0^5 t^3\sqrt{1+t^2}\,dt$
Now, let's use the substitution:
$\displaystyle t=\tan(\theta)\,\therefore\,dt=\sec^2( \theta)\,d \theta$ and we have:
$\displaystyle S=36\pi\int_0^{\tan^{-1}(5)} \tan^3(\theta)\sqrt{1+\tan^2(\theta)}\,sec^2( \theta)\,d \theta$
$\displaystyle S=36\pi\int_0^{\tan^{-1}(5)} \tan^3(\theta)\sec^3(\theta)\,d\theta$
$\displaystyle S=36\pi\int_0^{\tan^{-1}(5)} \frac{\sin(\theta)(1-\cos^2(\theta))}{\cos^6(\theta)}\,d\theta$
Now, let's try the substitution:
$u=\cos(\theta)\,\therefore\,du=-\sin(\theta)\,d \theta)$ and we have:
$\displaystyle S=36\pi\int_{\frac{1}{\sqrt{26}}}^{1} \frac{1-u^2}{u^6}\,du$
$\displaystyle S=36\pi\int_{\frac{1}{\sqrt{26}}}^{1} u^{-6}-u^{-4}\,du$
$\displaystyle S=36\pi\left[\frac{u^{-5}}{-5}-\frac{u^{-3}}{-3} \right]_{\frac{1}{\sqrt{26}}}^{1}$
$\displaystyle S=\frac{12\pi}{5}\left[5u^{-3}-3u^{-5} \right]_{\frac{1}{\sqrt{26}}}^{1}$
$\displaystyle S=\frac{12\pi}{5}\left(\left(5(1)^{-3}-3(1)^{-5} \right)- \left(5\left(\frac{1}{\sqrt{26}} \right)^{-3}-3\left(\frac{1}{\sqrt{26}} \right)^{-5} \right) \right)$
$\displaystyle S=\frac{12\pi}{5}\left(5-3-130\sqrt{26}+2028\sqrt{26} \right)$
$\displaystyle S=\frac{12\pi}{5}\left(2+1898\sqrt{26} \right)$
$\displaystyle S=\frac{24\pi}{5}\left(1+949\sqrt{26} \right)$
Just a remark to reduce computations ..
Here we don't need a geometric substitution :S=36\pi\int_0^5 t^3\sqrt{1+t^2}\,dt
rewrite as S=18\pi\int_0^5 2t \cdot t^2\sqrt{1+t^2}\,dtWe can use the substitution u=1+t^2 \,\,\Rightarrow \,\, t^2=u-1so we have du=2t\, dtThe integral becomes as the following :S=18\pi \int_1^{26} (u-1)\sqrt{u}\,duS=18\pi \int_1^{26} \sqrt{u^3}-\sqrt{u}\,du
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
