- #71
- 24,488
- 15,021
Bell's theorem, i.e., the validity of Bell's inequalities is derived from two assumptions: "locality" and "realism". Locality simply means that the setting of the hidden variables in the very beginning determines their setting once and for all, including their probabilistic description in terms of standard probability theory. It's a very weak condition, and the more constraining condition of "locality" in the sense of "microcausality" of relativistic QFT of course, fulfills this condition.Simple question said:If I understood it correctly, QFT and micro-causality explicitly forbid anything space-like to have any predictive(or even retro) effect on the solution of QM local "prediction". Fine.
But does it not mean the Bell's theorem is (and was) intended to show that if NATURE (the territory) (not QM (the map)), is indeed compatible with QM "logic", then NATURE contains NON-LOCAL "processes" ?
Realism means that all observables always take determined values given the values of the hidden variables, i.e., the probabilistic description is necessary only because of our ignorance of these values due to the ignorance about the hidden variables, and thus the statistics is in terms of standard probability theory for all observables given any probability distribution of the hidden variables (see Weinberg, Lectures on Quantum Mechanics, 2nd edition).
The latter is of course not fulfilled for any type of QT, including relativistic local QFT. Since relativistic local QFT fulfills for sure the locality assumption and violates Bell's inequalities in accordance with the observations made in Bell tests, it must be "realism" which is violated by QT and obviously also by Nature.
Relativistic local QFT is perfectly local and causal. Causality only means that if the state of the system is given in the past it's uniquely determined in the future (given the dynamical laws of the theory under consideration), and that's the case for all QTs, even in the more restricted sense that there's not even memory, i.e., it's sufficient to know the state at a given point in time to know the state at any later time.Simple question said:So I think it follows that QM is incomplete, at least for those that think that QM must be a local-causal only theory (in SR sense), and that anything else is irrelevant, and can be safely ignored, or worse deemed a "interpretation issue".
Whether or not QT is "complete" is a pretty empty question. At least in one sense it's incomplete, because there's no satisfactory quantum description of the gravitational interaction ("quantum gravity"). As any so far known physical theory it thus has its restricted realm of applicability.
