High voltage surface conduction prevention
High voltage surface conduction issues are likely causing spark-like sounds from a ceiling-mounted cable connected to a 20kV source. The discussion highlights the importance of proper insulation and the potential effects of moisture and dust accumulation, which can lead to arcing and surface conduction. Users are encouraged to provide detailed descriptions of their setups, including cable specifications and connector types, to facilitate better troubleshooting. The presence of nearby hardware may also contribute to capacitive coupling, exacerbating the problem. Effective solutions may involve using high voltage insulators similar to those found on power poles to mitigate these risks.
zaillian
I have a high voltage source feeding a cable which is attached to the ceiling with plastic hooks, finally descending to the properly isolated source. The high voltage output is a typical terminal that the cable is connected to.
When the supply is turned on, some spark like sounds emerge from the ceiling. This is probably caused by the surface conduction of the cable. What is the best method to stop the surface conduction of a cable when high voltages in the 20KV range are involved?
Can you describe your setup in more detail, and maybe attach a few pictures? Use the "Attach files" link below the Edit window to upload the files. What is your background so far in working with high voltages? What are the cable specs and the exact connectors used?
Likes Lord Jestocost
Is this a guess? Can you see this arcing if you are able to darken the room? You may have hardware nearby the cable that is capacitively coupled so it charges up and then discharges into something else. High voltage can easily fool a person.
AC or DC ?
Moisture rises and condenses onto the ceiling, and insulators. Dust is attracted by electrostatic charges, then is baked by the corona onto the surface.
22 kV insulators, exposed on power poles, have four or five large discs of glass or ceramic, and are washed by the rain.
After operation for some time, when you look closely at the structure of the building, you may also find scorched wood, near where the plastic hooks are attached.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
