Hodge duality and differential forms
PhyAmateur
If we have,$$A=d[(\bar{\alpha}-\alpha)(dt+\lambda)]$$
where $$\alpha$$ is a complex function and $$\lambda$$ is a 1-form. t here represents the time coordinate.
If we want to calculate $$d\star A=0$$ where $$\star$$ is hodge star, we get if I did my calculations correctly $$\nabla^2[(\bar{\alpha}-\alpha)(dt+\lambda)]=0$$
From the product rule, we get $$(\bar{\alpha}-\alpha)\nabla^2(dt+\lambda)+ (dt+\lambda)\nabla^2 (\bar{\alpha}-\alpha) +2 \nabla^2(\bar{\alpha}-\alpha)\nabla^2(dt+\lambda)=0$$
Does it mean here that each term must equal zero and thus since $$(\bar{\alpha}-\alpha)$$ can not be zero in the first term so $$\nabla^2(dt+\lambda)=0$$ thus killing with it the third term in the equation and only leaving the second term?
That is simplifying the above equation, we get, $$(dt+\lambda)\nabla^2 (\bar{\alpha}-\alpha)=0$$ thus leaving us with $$\nabla^2 (\bar{\alpha}-\alpha)=0$$
Can this step be done?
I suppose you're working on a Lorentzian manifold, Minkowski space?
What is ##\nabla^2##, the Hodge-Laplacian?
If you're doing physics, why choose a particular "time coordinate"?
$$\nabla^2$$ is the normal laplacian of (x,y,z). t is chosen like this such that dt is a 1 form.
Right, so you're working in a Newtonian spacetime. Maybe using the fact that
$$\Delta = \left( d + d^* \right)^2 = d d^* + d^* d $$
with ##d^*## being the codifferential will help. Btw, if you're doing Cartan calculus ##\nabla^2## is a bad notation for the Hodge-Laplace / Laplace-Beltrami operator, because it suggests that you're applying the connection twice.
So yes, considering that I used this notation istead of $\nabla^2$ is my final answer correct or at least is the procedure correct that I considered all terms must be set equal to zero?
