I Hölder and log-Hölder continuity
hilbert2
Insights Author
TL;DR Summary
About the difference of Hölder and log-Hölder continuity.
Now, there's this conventional definition of the Hölder continuity of a function ##f## defined on ##[a,b]\subset\mathbb{R}##:
For some real numbers ##C>0## and ##\alpha >0##, and any ##x,y\in [a,b]##, ##|f(x) - f(y)|<C|x-y|^{\alpha}##.
However, this does not include functions like ##f(x) = -\frac{1}{\log x}## because its value goes to zero "too suddenly" when approaching ##x=0## from the positive side. This kind of functions are, however, log-Hölder continuous which is defined as
For some real number ##C>0##, and any ##x,y\in [a,b]##, ##|f(x) - f(y)|<-\frac{C}{\log |x-y|}##,
or something like that.
But, how about a function like ##f(x)=\frac{1}{\log (-\log x)}## ? Is this also log-Hölder continuous? Or if it isn't, is there some less restrictive version the log-Hölder condition (defined in some actual publication or textbook) that includes also that function?
Edit: Note that here I define ##f(0) = 0## and the interval ##[a,b]## is supposed to contain ##0##, usually as the left endpoint.
There seems to be a continuity property less restrictive than log-Hölder - the ##\gamma##-log-Lipschitz property:
For some ##C,M,\gamma \in \mathbb{R}## and any ##x,y\in [a,b]## with ##|x-y|<1##, the inequality
##\displaystyle|f(x) - f(y)|\leq C |x-y |\left(\log \frac{M}{|x-y|}\right)^\gamma## holds.
If this is supposed to be a better upper limit than the log-Hölder, we probably have ##C>1## and ##\gamma \in ]0,1[##.
Now if I try to show that the function ##f(x) = \frac{1}{\log (-\log x)}## doesn't even have this property on an interval containing ##0##, I can choose ##y=0## and set
##x=\exp (-\exp A)##
which leads to
##\displaystyle|f(x)| = \frac{1}{|A|} \leq \exp (-\exp A)\left[\log M + \exp A\right]^\gamma##
Then to prove the claim by contradiction, I should find some value of ##A\in\mathbb{R}## so that the opposite
##\displaystyle|f(x)| = \frac{1}{|A|} > \exp (-\exp A)\left[\log M + \exp A\right]^\gamma##
is true. It shouldn't be impossible because the ##\exp(-\exp A)## on RHS approaches zero really fast when ##A## is increased, but I'm not sure yet how to show this.
Yes, the function ##f(x)=\frac{1}{\log (-\log x)}## is also log-Hölder continuous. This is because it satisfies the condition that for some real number ##C>0## and any ##x,y\in [a,b]##, ##|f(x) - f(y)|<-\frac{C}{\log |x-y|}##. In this case, the value of ##f(x)## does not go to zero "too suddenly" as ##x## approaches ##0## from the positive side, so it satisfies the log-Hölder condition.
There may be a less restrictive version of the log-Hölder condition that includes this function, but it would depend on the specific context in which it is being used. It is best to consult a publication or textbook on the topic to see if there is a version that includes this function.
